Whirlpool GEW9250 Electric Dryer Logo
Brooke Egan Posted on Aug 13, 2017
I have an electric whirlpool duet dryer that wont turn on when the power button is pushed. but i noticed the heavy duty light on the dial stays on unless I unplug the machine. we have already replaced the control board and had a technician out that could not fix it. sometimes it works and that is when the light on the dial will move but mostly it stays stuck on heavy duty and its lit up.
1 Related Answer
Anonymous
  • 249 Answers
  • Posted on Nov 30, 2008
SOURCE: whirlpool duet dryer wont start
sounds like the door switch
Dryer wont turn on
We would suggest calling Whirlpool Customer Service in order to troubleshoot what could be happening with the dryer. Please contact us at 1-800-253-1301 and we would be happy to look into the dryer issue with you.
Dryer run but does not heat
Chedk your breakers the dryer will run on 110v but wont heat
I have a Whirlpool Duet Dryer that is locked on the heavy duty cycle, I cant switch to another setting, it wont cancel out. I've tried unplugging it for some time to reset it. It is still stuck o
when you unplug it you're resetting the computer board just like your house computer does,so if it helped by unplugging it i would have to say the board is bad and needs to be replaced.next time send the model number off of the machine
Whirlpool duet does not turn on when the power button is pushed no lights come and no sound the interior light works and then theres the odd time you push the power button and it works fine
sounds like the door switch/latch is going bad. You can test it here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
My duet dryer will not run
Is there a fualt code that is listed. you might need a new board. It sounds to me like the board has a short.
4helpful
Error code E6 on a Whirlpool Duet Dryer
Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
Dryer knob does not control times or cycles
i can be either the timer , control board or check to see if there is a wire brush runing on the drum this is a sensor and if it is worn down it give funny readings
2answers
Dryer wont start - no lights
Dryer door does not think it is closed. There is a sensor on the top of the door that is probably not making contact with the door. Trying pushing the top part of the door and holding it then press the start button.. if the unit starts running then you know what it is. I just had one of these dryers delivered today and had to find out about this by myself tonight!!
Your answer to my whirlpool duet dryer problem
You have got a bad connection somewhere, it could be in the timer unit,or the door switch, take off the top and shake the wires with a rubber glove on, the machine would have to be on to do this,be careful,you can by pass the switch by joining the two wires If there is just two.If only I had it in my work shop, but Ireland is too far away good luck.top of the morning to you as all us paddys say!
Nov 30, 2008 • Dryers
1helpful
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
