The photos are accessible on the camera and can be viewed, but when I plug the camera into a computer with the cable it shows only a few data files and no photos!
Videos can be viewed on the computer with Winamp but still don't show when i open the Sony memory stick drive.
I have also tried using a separate USB Memory card reader and that doesn't work either.
is it possible that the memory stick may have a virus, and what can i do about that?
Any help will be much appreciated,
Thank you,
Felix Miller.
Hey all actual solution...sort of will get you your files well it worked for me.
i have winrar on my windows 7 pc but should work for anything with winrar.
Hope this has been helpful to all reading this and everyone who posted the problem :D
Hi there,no mention of wheather or not you have the camera software loaded or which operating system you are using either so this may help.
When you plug camera in to the computer do you get the
FOUND NEW DISK message???There are 4 messages normally with XP...
If XP OR Vista it will auto recognise,
Let the new device install the drivers,let it auto install
(follow the wizards step by step)
when done it will show you device is ready for use,
this should allow you access to the computers new device as a memorycard or another removable drive,
if using USB to connect then you should have a couple of folders,
One for photos and one for video files,
DCIM Digital Camera IMages.....
should be able to copy and paste from these folders or the cameras software will have an import function and you select where to put the contents and away you go.
If using 98 --- This may need the drivers to work correctly too.......
You get them from the cameras software disk or download them for the manufacturers site.
Hope this helps,Please let me know if you need more assistance,
If you do need assistance I will need the models of the camera and the computer and OS your using,,,,,Thanks and good luck
MISTERDJ
mine got lock up and i can't put anything.
Dear Sir,
Earlier I use to get both Folders but today when Im connected my camera only one folder is visible. Using XP. Model DSC W55.
thanks
Waiting for reply
Hi!
I Have cybershot Sony camera (DSC W55), many times used same memory stick (1GB)and taken more than 5k photo. Today out of two folder DCIM folder is missing due to this not able to copy photo and video's.how do I copy these photos on my PC.
thx
