SOURCE: put front gasket back on
start on the door side of the appliance put the top of the circle in first this should allow you to stretch the spring a little to make it go on
its a pain and it kills the tips of your fingers try not to overstrech it because it will fall off all the time
SOURCE: My Bosch Nexxt Premium washer - WFMC 6400UC -
It happened , because u had water in there.. u ********
SOURCE: Bosch Nexxt Essence WFMC 2100
Take pump access door off ck to see if leaks is coming for there if it is remove black pump cover clean and resecure. if not leaking
remove two screws on rear of machine and slide top off ck drain hose inside machine to see if o ring is leaking.
SOURCE: where can I order a
Hi Toni from retired Englishman in SW France,
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
