Turned oven on with set temp of 350 degrees, after about 30 mins turned temp up to 400 degrees after the meal was finished turned off oven, but the oven would not shut down continued to to heat. I went to the circut breaker and turned off, after about 2 hours went back to the circuit breaker and flipped swith to on. The oven shows that it is not on no temp to read but the element in the oven started to heat up again so I flipped the power breaker to turn off oven.
Karen, We are sorry to hear about your Oven. We are happy to look into your concerns but we will need your your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to [email protected].
SOURCE: Have Whirlpool Electric Range super capacity 465
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^TF
