If you wish to get some details; visit the site linked here. Pull up older posts. To make it a hard reset, just unplug the device from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. http://electronicshelponline.blogspot.com/
Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Amazon com Charm sonic Wireless Portable Bluetooth 4 1 Receiver Wireless...
These are the following steps to reset your Denon receiver:
1. Save the information currently stored in your Denon receiver, such as device commands and multi-zone controls. Some Denon receivers can control multiple rooms and each room needs to be setup properly to provide the correct controls. If the receiver was installed professionally it may be best to contact the installer before resetting the device.
2.Press the "Power" button or the "On/ Standby" button to shut off the receiver. On some receivers it is best to press the button on the device instead of the remote as the remote will normally put the receiver in standby mode. Ensure the display and all other lights on the device are off. Do not unplug the Denon receiver as it will not reset.
3.Press the "Power" button and at the same time press two buttons on the front panel, which are determined by the model Denon you own. Most receivers identify the two buttons inside the user's manual, while some older Denon receivers require you contact Denon for the right button combination. For example, some Denon models require the "Standard" and "DSP Simulation" buttons to be pressed simultaneously.
4.The display will start flashing at about one second intervals. Release the two buttons. Turn on the receiver by pressing the "Power" or the "On/ Standby" button to verify the previous settings and saved radio stations have been erased. If the interface does not flash, the reset was not complete and needs to be re-done. Re-enter the previous settings to ensure there are no further issues with the receiver.
Read more: How to Reset Denon Receivers ' eHow.com http://www.ehow.com/how_7441680_reset-denon-receivers.html#ixzz1wpEtIRTB
If the information helped you out please give some me some ratings. Thanks
SOURCE: I have this DENON AVR4800, and there is no osd.
You need to use the monitor output on the denon and go to a video input on your tv, be sure the tv is set to the video input you plugged into on the tv input, then take the denon remote and hit the setup button, should show a on-screen setup
