Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2061 motor starts running and then stops
Hi, I would really appreciate some assistance on this problem. The Maxx WFL 2061 motor accelarates (either for a wash cycle or spinning cycle) and then stops again. It continues to do this every 30 seconds or so.   I have tested with an empty drum to be sure it is not an "unbalanced load problem"
Thank you
Rodney
  • rodney512 Nov 29, 2008
    Thanks for responding Tresilla.
    What I mean is that the motor starts speeding up but before it gets to normal operating speed, it seems to loose power and slows down to a complete standstill. Every 30 seconds or so, it repeats this cycle.
    I removed the tacho cover and the magnet is firmly mounted on the end of the shaft.
    The pickup wires look ok.
    Thank you
    Rodney
  • lr99 Dec 01, 2008
    manual
    New Friend:
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to
realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace pkurdnirund@hotmail.com , peacepattaya@gmail.com
Posted on Dec 31, 2011
    President:
  • 1,462 Answers
I nassume you mean that motor accerates to an uncontrolled speed.
check the motor tacho - mounted at the opposite end to the pulley. tacho consists of a circular magnet surrounded by a pickup. magnet may have unscrewed itself from the motor shaft
Posted on Nov 29, 2008
6ya staff
SOURCE:
Bosch Axxis WFL 2060 Front Load Washer - DRUM DOESN'T CYCLE
This seems to be a fault with the program controller unit or the water level sensor. The program does not advance further after the inlet is filled but operates the drain to exit water. Now the water level sensor must be checked as if this is not working in the stipulated time it will drain out. Also unless the water level sensor contacts on reaching of set level the motor must start.http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Mar 14, 2012 | Washing Machines
Hi I have a Bosch WFL226 MAXX. The wash programmes seem to work OK - the motor operates the drum and the pump works fine and drains the machine. The water level vacuum switch seems ok (it stops it...
Bosch WFL226 MAXX This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 21, 2010 | Washing Machines
My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Dec 08, 2009 | Washing Machines
I have a bosch maxx 1000 (wfl2000au/30) machine will not spin. pupm impeller was jammed by a bobby pin. i removed the bobby pin. when machine is on spin cycle only the pump opperates. does not spin at all....
If there is no water in washer, and it will not spin, I suggest you remove the motor, and check the brushes.
If they are less than 3 or 4mm long, they need replacing.
Hope this helps.
Dec 05, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Maxx 6 WFL 2061 Front Loader W/M
brushes usually available on ebay,
if the drum rotates but does not spin, this could likely be brushes or component problem (i.e triac or relay) on control PCB. - the latter was the problem i had and this was easily spotted as a blackened track on the Relay on the pcb.
Brushes should be ~£5. - check the existing brushes first before buying them.
fitting is easy, BUT a word of warning..which you probably know anyway..
before meddling though in the machine, locate the large capacitor and with electical screwdriver and discharge all the terminals to earth first! - YOU MUST DO THIS TO AVOID ELECTRIC SHOCK!! - even if the machine is unplugged.
remove motor & undo the back plate to release old brushes.
clean of motor of any excess carbon dust, - this can eventually cause arching if not cleaned away.
reassemble and fit all plugs back.
THEN TAKE 5 MINUTES TO CHECK WHAT YOU HAVE DONE BEFORE SWITCHING ON. -
Do not rush anything - take your time.
Mar 24, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
1,140 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
