Hi ! for a free wiring diagram, please visit the website below. If you need more information about a specific electrical issue you can reach me at [email protected].
http://www.motorpartstore.com. good luck and have a nice day.
SOURCE: Wiring diagram for the Harley Davidson 2007 FXDB
If you are gonna work on your own Harley, shell out the $60.00 for an H-D manual. They have a basic wiring diagram inside.
SOURCE: I don't understand my wiring diagram.How does the
Hi and welcome to FixYa,
If the starter relay in your version uses blue / white and red / white wires, then to my understanding, connection would be:
Good luck and thank you for asking FixYa.
SOURCE: i need a wire diagram
The wiring is simple for a starter. You have a starter solenoid on the bike and a starter relay. When you press the button to start your bike, the button has a wire that runs to the relay. This triggers the coil in the relay and pulls the contacts in. You have three wires that run to the relay for the starter. One hot wire, a trigger wire from the starter button and a wire from the relay to the solenoid. When you press the button, the relay pulls in and makes the wire going to the solenoid "Hot".
The solenoid has three wires going to it. The large battery cable goes to the "long post" of the solenoid, There's another battery cable going to the starter from the bottom of the solenoid, The wire from the starter relay goes to the small terminal of the solenoid. The small wire from the starter relay is the trigger wire for the starter solenoid. When this wire goes hot, it magnetizes the solenoid and pulls the plunger inward. The plunger bridges two large contacts in the solenoid to put high current voltage to the starter.
If you need a schematic, contact me directly at [email protected]. I cannot send a file via this medium but I can direct e-mail. Remind me of what you need when you contact me.
Good Luck
Steve
SOURCE: I am looking for a
Contact me directly at [email protected] . I have some wiring schematics with the five post switch. Please tell me what type of bike you're working on and I'll try to find something pretty close to what you are working with.
Steve
SOURCE: Starter will not turn over or even click - 1993
get a repair book online--the batt shudbe at 12.6v--titen all wires there and at starter--switch cud be bad
