Hi: I just found this website & have a problem. My Sansa Clip + is stuck on the 2nd screen after you turn it on. 1st screen says "Sandisk" - 2nd (stuck) screen is the "4-leaf clover" design. It will not budge from there. I've had the player for 4 years & this is the 1st problem, but I've tried everything. Can you help a newbie like me? Pls. let me know.
SOURCE: SanDisk Sansa Clip is stuck on connected.
Do this first:
http://forums.sandisk.com/sansa/board/message?board.id=clip&message.id=849&query.id=66344#M849
Then update your firmware:
http://forums.sandisk.com/sansa/board/message?board.id=clip&thread.id=718
I think you need to connect to a PC though, not sure
SOURCE: Sansa Clip Frozen at startup Screen
since windows is able to recognize the device I would recommend you to update the firmware if you have not done so...this is the link for the firmware update...let me know the outccome...
http://sandisk.com/Retail/Default.aspx?CatID=1376
SOURCE: New SanDisk Sansa Clip freezes
if you hold up the power button on it for 10 to 15 seconds it will turn on. I'm sorry if it doesn't work for you..but it worked for me
SOURCE: my sandisk sansa clip 1gb wont turn on
Make sure the player is fully charged.
1. Connect the player to the PC.
2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode,
1. Turn device OFF.
2. Slide the Hold switch down to Lock (orange color showing).
3. Press and hold the center button while connecting the device to the PC.then connect it to the PC.
Next Be sure the battery is charged
1. Leave the player connected for approximately 2 hours to charge.
2. Disconnect the player from the PC.
3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
SOURCE: want drivers for Sandisk Sansa clip 2gb mp3 player
http://www.sandisk.com/sandisk-support/driver-download-wizard
