Sylvania hdtv model lc320sl1 will turn on but does not get picture.... sound works.... various colored lines and or scrambled picture appears at best
Picture will not show when tv is turned on..... sound is there but no picture. sometimes colored lines appear vertically or scrambled picture at best
    Top Expert:
  • 14,553 Answers
Let me start at the beginning---Likely a bad main board in your case but nothing is sure in this type of set.
Main board controls all information to the front screen and communicates to various boards---There really is almost never a simple "that part is bad solution" as any board, the power supply, the main, etc can cause issues.
It can even be a issue with the front screen unit--called a display panel.
You might consider doing some research on the set by Google of the model number with "parts" to get an idea what is available and what potential parts cost might be.
If a main board is bad it will average from one to two hundred just for the part----if issue is the panel you are done--part if even available is more than set cost when new.
Let me know if you have questions.
Posted on Jun 03, 2012
6ya staff
SOURCE:
Anonymous
  • 3130 Answers
SOURCE: vertical flickering color lines instead of pictures
Soory man there is no deflection yoke or vertical output IC in a plasma TV set.LOL This person has a problem with whats called the substain power supply or bad caoacitors in the main supply. there is also a possibility that the set has a bad tuner. Only performing test on the set will determine the problem.
Posted on Mar 23, 2007
Anonymous
SOURCE: When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Posted on Mar 03, 2009
Anonymous
  • 23 Answers
SOURCE: plasma TV with vertical lines
EASY! ok the 4th video processing unit is malfunctioning, if it is a Piano affect like the keys on the piano, then that can be fixed under your 1year warrenty after your 1year warrenty it will cost $200, but i could be wrong, i never studied panasonic plasma casue they ****, next time get a samsung.
the worst contrast and video ajustments, thats a panasonic.
trust me i am the flat pannel guru!
Posted on May 02, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: screen scrambles into various colors and freezes
TV requires main board replacement because problem seems in video processing section.
Main board is available at Shop Jimmy on reasonable price. (click shop jimmy link to see an image of main board)
Posted on Jun 12, 2009
Anonymous
  • 4 Answers
SOURCE: Vertical lines have appeared on my
if this tv is under warranty i would call samsung, there could be three board that could be going out on it one is the techon board, main board, but you also my need the ip board changed out to. i repair samsung all day long and i see this problem a bit.
Posted on Oct 18, 2009
Sylvania lc320sl1
in this television .if you see the digital television .its the inverter board. try a probe pull off the small cable of inverter board .and try to turn on the tv .if the light stay green the inverter is out. thanks
Dec 10, 2013 | Televison & Video
Tv had thin black line when turned on today whole screen scrambled
need to access the ez menu to reset the parameters u will need a tech to fo this
Jul 19, 2013 | Vizio VF550M 55 in. LCD HDTV
My tv when it turns on there is no color and after a while the colors appears, also the picture is distorded, any sugestions?
Its a older set and I have fixed and even owned one---bad solder connections and or convergence problems---can you describe better what it looks like when cold?
Nov 04, 2012 | Televison & Video
I cant turn the caption off on my sylvania model # lc320sl1
In the menu there should be a captioning section that you can highlight and turn it off
Jan 13, 2012 | Sylvania LC320SS8 32 in. LCD Television
I have an Emerson LC320EM8, the screen scrambled in various colors and freeze
What happens to the sound when the picture freezes? Also are you able to bring up the menu when it freezes?It sounds like a main A/V board issue but I would like to be sure.
Mar 09, 2011 | Emerson LC320EM9 32 in. LCD HDTV
My sylvania lc320sl1 won't turn on, the power light is red, blinks in green, but does not turn on. What should I do?
My sylvania 32 LC320SL1 HDTV tv will not turn on it stays in standby and when I click the power button the power light flash around ten times then the screen flashes on and says digital television in the bottom right then goes back into standby its make a click sound as it goes from power on to standy by
Jan 07, 2011 | Sylvania Televison & Video
Scrambled picture
Which caps on which boards as that sounds like a issue with the signal and FMT PCB. The v26 chassis like yours has problems with bad caps on the DM, Signal, FMT and the PWB and terminal
Jun 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Picture appears to be trying to scramble
Bad hyper board == No longer available
Bad electrolytic capacitors on board need changing-
Let me know if you need more info......T.
Nov 01, 2007 | Toshiba 51H84 51" Rear Projection...
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
