We just moved and had to change the power cord on the dryer to fit the new outlet. After changing the cord the dryer runs but it does not heat and the timer does not move. What's wrong?
SOURCE: whirlpool dryer: supreme Not heating up
Hi thanks for the question. the problem could be the thermal fuse located at the back . remove back panel. on the air duct . a small piece of plastic with 2 blue wires to it . replace the thermal fuse thanks .the appliance doc
SOURCE: My dryer works but no heat
On the backside near the bottom of the element is a limit that has 3 wires. The smaller wire goes up to the timer and it powers up the timer motor in the auto cycle. On the blower housing is a cycling thermistat with 4 wires.(2 small and 2 big wires) The 2 smaller wires are connected to a tiny heater in the cycle thermistat. To get from cotton to permapress we simply heat up the little old heater and the cycle thermistat shuts down faster. Clever heh? Where wuz I? OK: While the heater is fired up the timer motor will not move. When the heater stops working the timer moves forward. So as the clothes get dryer, the heater comes on less and less and the timer motor gets more and more power till finally the heater is no longer is needed. Then the timer goes on over to the end. Pretty dang clever ain't it? Well what can go wrong? The cycling thermistat is causing the limit to control the heat( you would know because the clothes would be all hot and wrinkly) OR the vent to outside is clogged. As a result the smaller Hi limit atop the heater chamber is blown. a Replace the control thermistat AND that 3 wire limit on the bottom of the heaterlong with it's very blown little cousin atop the heater chamber.. Oh yeah. Remove the vent pipe and get the gunk out:
SEE THE PICTORAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: damp clothes
the dryer is not the problem the problem is the house vent it is restricted some where
SOURCE: Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
SOURCE: whirpool amana dryer runs but no heat
HI, the timer motor is malfunctioning. this can affect the way you dryer heats in this case. I would advise to check the thermal fuse before replacing the timer. it is located on the blower house or, on the vent duct. in will show no continuity if defective. replace the timer if the thermal fuse is showing good continuity when measure with a meter.
Thanks, we did change from the four prong to a three prong.
Then you will want the two outer wires on the cord on the two outer terminals on the dryer terminal block, and the center (ground) on the center terminal.
