Craftsman WeedWacker Gas Trimmer 25cc 2-Cycle Curved Shaft Logo
Posted on May 31, 2012
Craftsman model 358798230
Trimer starts up fine starts to run stronger then dies
5 Related Answers
Dwain Pippen
  • 377 Answers
  • Posted on May 26, 2009
SOURCE: Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
Anonymous
  • 13 Answers
  • Posted on Jul 21, 2009
SOURCE: Starts up fine then dies when hot
your automatic choke is defalting
Anonymous
  • Posted on Aug 28, 2009
SOURCE: Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
Anonymous
  • 138 Answers
  • Posted on Sep 22, 2009
SOURCE: 2 year old craftsman 42
if it restarts immediately, check the vent in the gas cap for restriction. also, the solenoid on the bottom of the carburetor may be sticking or getting weak. if you have to let it sit for awhile before it retarts, the ignition module may be breaking down when it heats up. i'd bet on the gas cap or solenoid though
Anonymous
  • Posted on Jun 30, 2010
SOURCE: 2003 craftsman ys4500 model number917 276680 died
Mine did same thing, need to manually adjust choke. If you raise hood and adjust your throttle you will see that when you press up to choke that it actually hits & pushed in choke. But when you back off if it is like mine the choke doesn't come off, so I manually pulled choke to off & mine started right up. I am still trying to find how or where cable came off for the choke to be adjusted by throttle lever. That is why I was on here looking for photo of engine.
1helpful
2answers
Craftsman Lawn Tractor Model 917.271120 died while mowing & will NOT turn over. Was starting & running fine up until then. Where are the fuses located on this model?
Back side of dashboard. See manual.
https://www.manualslib.com/manual/480353/Craftsman-917-271120.html
To start, typical rider mower requires BRAKE ON, PTO OFF, and Transmission NEUTRAL. Some require operator in seat.
1helpful
CRAFTSMAN WEEDWACKER 316-791860, WILL NOT START. HAS SPARK, FUEL LINES FILL UP, WAS RUNNING FINE, DIED, STARTED NEXT AM, RAN 5 MINS THEN DIED AND WOULDN'T RESTART
Two things which may be the problem: 1) carb need to be rebuilt or replaced, and 2) you need a new spark plug. The carb with shipping is around $50.00 from sears ( http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-3167918602008/0247/1503820/P0805032/00001?blt=06&prst=&shdMod= ) A sparkplug can be had at any small engine repair shop and most auto parts stores for less than $5.00 Start with the cheap solution... Also make certain you have fresh gas and that the oil mix is correct.
I have a craftsman gt 5000 model 917.276220 runs fine but when mowing deck is engaged it wants to die when under a load or cutting tall grass, it will stay running but when i start to cut it bogs down?
not possitive, but sounds like 1 of the bearings on the mower deck is starting to seaze up.I would start with that. Remove the deck and belts and check all the pullys and bearings for free movement.
1helpful
I need a carburator for my craftsman line trimer
You can get those online. Take the carb off and clean is so you can see the name and model of the carb. Once you have that, just go online and find the part. I sometimes use jackssmallengines.com. I get the correct part in a timely manner. Good luck...Lee
2 year old craftsman 42" deck tractor runs fine for 15 minutes then sputters and dies. Will start, run 2-3 minutes, die again. Leave sit will run for 20 minutes.
2answers
21helpful
4answers
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
