Washing Machines Logo
Anonymous Posted on May 30, 2012
Maytag Washer Lid lock light
Maytag washing machine model MVWC300XW I've only had it a month. When you press start button green sensor light goes on as well as red lid lock light. Now in the past 5 days, when you press start, green sensor light goes on, but red lid lock comes on too, but about 10 seconds in, the red light starts to blink, the washer unlocks, then the red light goes on again, and re-locks, and then it continues?? I NEVER saw it do this double lock and red light blinking before, it just started doing that.
  • Anonymous Jun 01, 2012
    It doesn't matter now. Apparently, there is something more serious going on, since last night, the washer leaked all over my basement. Keep in mind, I have no children, and the washer is a month old. I contacted the place I bought it from, and they are sending someone out tomorrow 6/2/12. I told them that if it needs more than one hose, I want a new washer. Thanks, anyway. :(
  • Anonymous Jun 02, 2012
    No, it's a Centennial. But as I said we had to have a technician come out and check, why it leaked. And it was the hoses in the back, the washer warped, after only one month????? But he did put a tester, on the sensors, and what you said Jason Kennidy is correct. Thanks
Jason Kennidy
Level 3:
  • Maytag Master 1,344 Answers
  • Posted on Jun 02, 2012
Jason Kennidy
Maytag Master
Level 3:
Answers
1344
Questions
0
Helped
370018
Points
4021
Its normal for the machine to cycle the lock before starting its cycle. I'm assuming your machine is a bravos style.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
2 Related Answers
Anonymous
  • 4323 Answers
  • Posted on Sep 16, 2011
SOURCE: WTW5550XW0 Whirlpool model Cabrio When
Hi
First make sure to test the lid switch assembly, you can jump it to test it. If the lid switch and motor is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
A
Anonymous
  • Posted on Aug 29, 2008
SOURCE: lid lock stays on and constant beep on excellence washing machine
I am having the same issue and hope someone can post a solution. I have found a work around though. Mine does it when it is on a 'Regular' wash cycle, I found that if I put it on Permanent Press it works fine.
Magtag Centennial Washer Mod MVWC450XWO When I load, close lid, press start, green sensor light does not come on but red lid lock light starts blinking & lid locks & unlocks repeatedly while
Most likely it's the shift actuator but this washer design has had many problems. I would first unplug/replug all the wiring connectors. Tilt machine back for access to connectors for motor, capacitor, shift actuator and pump. You might want to pull the pump and make sure nothing is caught in there. Also do the connectors at the control board. Check for error codes as per tech manual and reset them. Perform the calibrate function. If nothing works, replace the shift actuator. It is a very high failure item on this washer design. If you buy it from here and it doesn't solve the problem, you can return it.
Unlocking your washer so it actually works.
If the green cycle light is flashing on then off, this usually means the cycle is paused. The lid lock should unlock when in pause mode, if not you will need to press and hold the "Pause/Play" button to clear the cycle completely, if there is water in the unit, it will drain first, then unlock the lid and be on standby to start a new cycle. Pleazer Appliance...
Possible Control Board Failure
This washer can be a pain to diagnose. Diagnostic document link. www.pwslaundry.com%2Ffiles%2Fdocs%2Fmaytag-whirlpool%2FTech-Sheet-W10280489-Rev-D.pdf&ei=K_JCU-yhK4Sh2AWIzYCQBA&usg=AFQjCNFDvmjAg2YHolMCS_ZHhzuw0_lb3w&sig2=OxlosNGyV7nkO4Rc48PNpw&bvm=bv.64367178,d.b2I&cad=rja
Follow the diagnostic directions. The first suspect part would be the mode shifter. Next I would suspect the main control board. All the testing info you need is in the service manual. Check/Ohm out the shifter first.
1helpful
I have a wtw5600xw0 Whirlpool washer. When I press the start button the sensing light and lid lock lights turn on. Then after a few seconds the lid lock light goes off and the sensing light stays...
Swich off the machine, try some WD40 on the door mechanism (on machine lock, not on the door) and open & shut for a minute or two. Then try the machine, spin only just to try.
Rate pl, if solved, or dont!
Source
Maytag MGD 9700SQ. When I press start, the sensoring light clicks on and that's it. I've cleaned out the lint, cleaned the sensors with alcohol. Will clean the vent, but it seems like a basic fix....
Hi Jamie: After checking all of this and if it still dont work you will need to put in a new control board.
Plug cord into live electrical outlet. Check for proper voltage.
Check fuse or reset circuit breaker.
Push any key to turn ON the clothes washer and press the Rotary Cycle Selector knob to start the clothes washer.
Close door and push the Rotary Cycle Selector knob to start the clothes washer.
Check to see if the clothes washer is in a pause, soak or suds period in the cycle. Wait briefly and it may start. If washer is in suds period, SU and DS will display alternately, instead of the time remaining.
Check for restricted drain system. If there is an electrical problem in the drain system, ND error will occur after 15 minutes.
Check water supply.
Check the line screen and water valve screen.
Check for loose connections at machine control board terminal connections
Replace machine control board.
In this link, with your model could find parts replacement:
- Maytag-Parts/Dryer-Parts/Model-MGD9700SQ
- partsearch/model.aspx?model_id=5140219
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
I have an Electrolux Washer machine model EWT959 and it currently problem is:- 1. "Choose Program & Start" 2. Once "Start/Pause" button pressed to start the wash 3. The message on...
It doesn't think the lid is actually closed indicating that there is a problem either with the lid lock or the lid locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
1helpful
My lid lock button is stuck and will not unlock....when i 1st went to the washer it was on spin and lid lock and i pressed the start button which is suppose to unlock this lide but that has not...
That happened to me once. I just unplugged the machine for a few mins and it released the lock when I plugged it back in. I've got my fingers crossed that it doesn't happen again.
1helpful
2answers
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
