Possibly needs a capacitor. Are you talking about the indoor or outdoor fan?Possibly needs a capacitor. Are you talking about the indoor or outdoor fan?
You can't post conmments that contain an email address.
It should be easy to replace. However, Condenser fans are "usually" very robust fans. It should come on with the compressor unless the environment is below freezing (but not likely a feature). I would double check all electrical connections to and from compressor and Condensor fan. the outside bottom fan near the compressor. If it continues you may jeopardize the compressor. It is not made to run without the condenser cooling fan.
Fans come off and on based on a thermostat usually installed on the radiator. Follow the wiring from the fan to the thermostat. Test by heating and an ohm or continuity meter.
The condenser fan in the back near the compressor comes on when the compressor comes on. The fan motor is the likely problem. It is easy to replace and inexpensive. Here is a link that should help Condenser fan replacement Spin the fan blade by hand or listen closely when it is making the noise to isolate it.
Now if the fan is not the problem and the noise is coming from the compressor, the compressor will likely need to be replaced. This is hardly ever worth the cost of the repair. You would be better off buying a new unit.
Seems like your blower motor is burning up. Its the motor that blows cool air across the refrigeration coil. If it is a whole house ac unit, probably your main blower motor for the furnace. If you are getting sweat, that means the compressor is compressing the refrigerant, and you should not smell anything from the outdoor unit, only from the furnace. Hope this helps.
