How do i Kenmore Refrigerator Water Line model 596.77533601
SOURCE: water line broken for Kenmore refrigerator near compressor
Cut off a piece of line and go to a good hardware store, they can show you how to fix it. Need a coupling, and a nut and ferrel. House water line goes on one end of coupling, nut and ferrel on the broken water line on fridge. A good hardware store will be able to show you how to fix.
SOURCE: Water line to Kenmore refigerator is brown
Some tubes turn brown gradually with age. This is normal. But if yours is not made of that material (not sure what its called), then it could be that the pipe is dirty. If this be the case, it is definitely better to get the line replaced, as it is definitely a health concern. I would recommend getting a filter fitted to the line as well, just as a precaution..
SOURCE: How do I disconnect quick connect water line on my refrigerator?
on both sides of the quick disconnect place your fingers on the "outer collars of it and push in and it should release your water lines by gently pulling them out.
SOURCE: kenmore refrigerator model 363.9711781 water appears daily
This water comes from a plugged up defrost drain tube. Do you see like a cup at the back of your refrigerator connecting using a plastic tube in a hole at the back of your refrigerator ? This cup collects dripping water from your freezer during a defrost cycle - you will notice a hole above it on the ceiling - what drips into this cup and drains out back the hole in your refrigerator wall and into a long drain tube extending down into the drip pan at the bottom of your refrigerator, usually sits ontop of the compressor or in newer systems next to the condenser fan and evaporates. If this drain tube is plugged up with debris water will backflow back into your fridge and drip against the wall and under your cripsers.
During a defrost cycle (when you hear the sizzling sounds and all motors are off, open the door and you should notice water dripping.
If you can manually remove the cup yourself you can pass a piece of pipe cleaner or long cable and dislodge whatever is blocking it or if you can't do that you will need to have it serviced, sometimes there is a seal around base of the plastic tube it's best you don't touch or break it. Makes ure the cup is firmly connected and inserted into the hole, you can try raising the fridge a bit, the front part so it is slightly inclined to back. If all fails, have it serviced, it is a very simply problem easy to repair and common too.
SOURCE: my kenmore refrigerator 106.56166500 quit
The line inside the freezer door is frozen . Turn the temp in the freezer , to warmer for a few days , and it should thaw . A dispensor heater is available , pt # WR49X10173 . Instructions come with the part .
