Question about Kenmore Refrigerators
There was an electrical short then are heard a hissing sound.
Could have the electrical spark causes a puncture to let the freon out?
    President:
  • 1,462 Answers
Very very unlikely
Posted on Nov 26, 2008
6ya staff
SOURCE:
Mcbr360 won't get cold at all hear as it come on and then click off I was busting up the ice in the freezer part and I hit something for liquid to spray out of somewhere needhelp ihave a small baby
oh oh seems like you punctured the freon line and now ur compressor will be out of freon and you will need to also replace the part you punctured, the line that is?
that liquid is what keeps ur frige cold!
Dec 18, 2016 | Refrigerators
The freezer is not cooling
unplug unit and this will cause a reset
did you try to defrost with knife
my friend just did that and punctured freon tube
Sep 28, 2014 | Refrigerators
Iwas cleaning refer and punctured the back. I hear air . what to do?
That is not air you have punctured a Freon line and could be expensive to repair depending on where
Jun 02, 2013 | U-Line 75R Refrigerator
The fan on the cooling unit outside is not turning on. It is and has been in the hundreds and the unit does not have any shade, could it just be too hot?
normally this will not affect the fan. it has an electric motor on it that has a breaker usually in the breaker box but sometimes it is in a subpanel. there are several things that can cause this like no power, low on freon, too much freon if you have just had it serviced, etc. with the power to the unit off, take a cloths hanger and put in the unit, being careful not to puncture the sides and see if the fan blades turn. if not then the motor is seized up. for some reason. even if the fan turns, you need a proffesional to take over as working with anything with freon is very dangerous not to mention the electrical components. it takes special equipment to check these. good luck
Sep 07, 2011 | Carrier 38CKC036 Air Conditioner
Chipping away ice in magic chef freezer section i punctured freon line in freezer panel can refridge still get cold
No, the fridge will not get cold any more. The coolant goes to the coils in the freezer. The fridge takes a small amount of cold air from the freezer to lower its temperature.
I am sorry to say that unless you can find a way to repair the puncture and refill the system with freon, you are going to have to buy another refrigerator.
Feb 05, 2010 | Magic Chef CTB1922 Top Freezer...
I punctured a hole in the freezer part will it still work?
UUUUUUUgh....not sure....
if you punctured the part that has the freon zig zagging through it and allowed the freon gas to escape then...nope...it will no longer work and it may cost quite a bit to get it repaired.....but...if you are lucky you may have only punctured the covering and not got into the part with the freon...turn it on and see how lucky you are.
Aug 21, 2009 | GE Refrigerators
Freezer puncture.  I punctured the liner to the freezer, creating a slight hole that emitted a vapor (presumably freon).  Must I repair it?  How do I repair it?
The freezer coil where you punctured is made of aluminum and there's not cheap way to fix it , but if the refrigerator is in good conditions you can replace the coil or get somebody to do it ( it is an expensive job).
Aug 15, 2009 | Whirlpool Refrigerators
Punctured an air-conditioner Freon line
when the freon is released from the unit,you have to repair the leak,pull a vacumm to rid any moisture in system then refill with freon,if you dont have the equipment,it would be cheaper to just replace the unit
Nov 09, 2008 | Maytag M7Y15F2A Air Conditioner
Punctured freezer
You should contact a local welding shop to fix the leak. The tubing is made from aluminum and can be hard to solder for someone who doesn't do it all the time. After that you need an appliance repairman to pit more freon in it. I guess the question is...how old is your freezer? More than 6 years old? Anything older than that, you may just want to get a new one.
Mar 20, 2008 | Sanyo SR-2410 Compact Refrigerator
Refrigerators Logo
59 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
