Ice maker works fine but freezer has ice (not frost) over everything as if water is spraying all over and then freezes; its getting thicker; any idea of what is causing this? Ice maker / cubes normal - no issues
SOURCE: Kenmore ice maker
If the ice ejector (the plastic part) is pointed down and not pointed between 10 and 3 o' clock the ice maker motor has failed or somethin is binding. Replacing the ice maker is probably the best bet.
SOURCE: no water to ice maker
SOURCE: ICE CUBE MAKER SMELLY ICE CUBES
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL
HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
SOURCE: Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
SOURCE: No ice from icemaker of Kenmore Elite model 106
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
