I need a wiring diagram for a canal r series electrical switch
There are several R series switches:
http://www.canal.com.tw/images/products/r.htm
Each appears to have terminal, or solder connections.
Electrician uses multimeter set to read ohms to check continuity of unknown switch.
Set to read ohms, and then test each terminal with other terminals, then flip the switch and repeat same test.
Then connect Hot wire to one terminal on the switch.
For example if there are two wires going to a 120Volt light bulb ... then one wire is Hot and the other Neutral. Cut the Hot wire and then connect the two cut ends to switch terminals. So the switch will turn the Hot wire on-and-off.
The neutral wire is not connected to the switch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
