Razor USA Razor Pocket Mod Electric Scooter Logo
fred ortiz Posted on May 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changed plug were u connect to charge the bella now the charger light stays green
Light stays green won't charge what next
Adam Fjeld
Level 3:
Genius:
  • Razor USA Master 1,508 Answers
  • Posted on May 22, 2012
Adam Fjeld
Razor USA Master
Level 3:
Genius:
Answers
1508
Questions
0
Helped
542599
Points
1761
Check the charger end with a multimeter and make sure that its showing that its putting out the correct voltage
Testimonial: "will do thanks "
Htc droid incredible 2 won't charge
FOr changing the charging port you have to take it to an authorized service center. it could be a software issue also.
2helpful
2answers
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
1helpful
I am getting a flashing green light when I try to charge my batteries on the Pronto M51 what does this mean
why did you change the batteries, did you verify that it wasn't the charger in the first place, sometime the charger will appear to charge but actually isn't. put a meter on one battery then plug in charger if voltage goes up charger is good if not look for loose connections and or bad charger.
2answers
Black & Decker Cordless Drill will not charge battery
Either the charging adapter is faulty or the battery is worn out.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
1helpful
Bella won't charge
check it with a multimeter and make sure that its putting out the correct amount of volts, it should be at least 24 volts
My hp compaq turned off by itself and won't turn on now, it won't even show the charging light when the charger is plugged in
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
2answers
I lost my manual to my duracell instant jumpstart . Just wanna know to properly recharge my unit.
I'm having the same problem where it won't take a charged. If you left it with a dead battery for say 6 months, it probably ruined the battery. You should have a charger for house current and car voltage charger. I guess your dead in the battery like me. I'm taking it to Battery Plus to check it out. It only had a 1 year limited warranty. Good Luck.
Top Razor USA Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Razor USA Toy Expert? Answer questions, earn points and help others
