After washer has finished it leaves a oil residue on clothes and side of bowl. It also smells when it does this like grease
SOURCE: Hi We Have a ge front load washer and dryer and
Front load washing machines develop a musty smell over time for several different reasons. Mostly due to using to much soap or the wrong type of soap. Since FL washers use much less water than traditional top loaders, regular soap with all the fillers and high sudzing agent within can not be rinsed out of your cloths or washer. The smell is caused by bacteria feeding off the soap scum residue left behind. Be sure you are using a HE detergent as is recommended by the manufacture.
Run and empty load with 1 cup of bleach placed in your soap dispensor and hot water to clean your washer. If the problem persists try "Washer Fresh" a cleaning agent specially made to take care of this problem.
After smell is gone repeat once a month to prevent reoccurace of problem
SOURCE: GE WASHER SPIN OUT PROBLEMS
Sounds like the suspension for the drum is having problems - there are usually springs holding the drum up and acting as shocks - one of the springs may have come off during an unbalanced load.
SOURCE: GE WBSR3140DW Top Load Washer Repair manual
Check your local Appliance Parts Stores, they usually have racks of repair manuals.
SOURCE: GE Aurora Front Load Washer leaves the clothes soaking wet
there is a filter under the washer door behind the panel...its white just unscrew it and clean out the filter and that should solve your problem.
