I am not sure that I will be able to get help on this. Our fridge is a GE. Model number VL15JZHR7-7, and is probably over 20 years old. Recently, we've noticed that both the fridge and freezer are stopping working. If we turn the temp knobs down to make it colder, everything then works again for a day or so. But we are running out of 'colder' space on the knobs now, and pretty soon wont be able to turn the fridge or freezer any colder to get it to kick in. Assuming that its something other than age, is there something that we can look at in the unit itself and try to fix it? Thanks in advance for any advice/help The Johnsons
From your comment. It's not that you have to defrost the parts, that's what they're called. "defrost timer", "defrost t-stat" and "heat element". Defrosting the whole fridge for a few days actually will clear the ice blockage if that's it but it will return in a couple weeks if the "defrost cycle" isn't doing its thing. A fridge typically goes into some form of "defrost cycle" to keep it "frost free". As an example, every 12 hours the compressor turns off and the evap. fan turns off then a heat element turns on to melt the light coating of ice on the "cooling coils". Once about 1/2 hour goes by the heating turns off and the cooling turns back on again. This repeats over and over to keep the ice from building up too much. If that cycle is broken, the ice will build and build till the whole coil is a block of ice. Then the air can't flow around it to provide cold air for the whole unit. It acts basically like putting a large block of ice in the freezer and keeping the doors closed... without a fan to move the cold air only the very lower portion of the freezer is cold, the rest is warm.
