Won't move in Fwd speed. Reverse and N are fine. Replaced all belts today-did not help.
SOURCE: require an operator's manual for a bolen troy bilt ltx 14 hydro
Go to... http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 Scroll down to bottom left and click on Owner Manuals. You will have to have the model and serial numbers from under the seat of your mower.
SOURCE: I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
SOURCE: Craftsman hydro gear transaxle problem
check the brake for sticking and dragging. check the bypass lever, make sure it's disengaged fully. did you just fix a flat rear tire? if so, the square key that links the axle and wheel fell out. do you pull a heavy garden cart around? that can stretch a belt and overheat the trans. last thought, check the belt and see if it came off a pulley, i know that should have been first but it's late and i'm tired. good night
SOURCE: troy bilt pony riding mower will go in reverse but
have a troy-bilt riding mower. place a gear in neutral and park it.
it dies instead idling. want to know why?
