Question about Bosch Classixx WFL 2066 Front Load Washer
I ahve a bosch classixx 1200 wae2416sgb. When it broke down all the spin lights were on suggesting the motor. I have changed the brushes. Cleared the fault code . Now when set to go on any wash cycle the main start light is on the spin 1200 is on and there is a periodic beeping (is this a door open warning) , the machine does nothing. Any clues?
6ya staff
SOURCE:
Anonymous
SOURCE: Classixx 6 1200 bosch washer...I've
You've put the child lock on! When powered key press the on/off button for 5 seconds. This will remove the key!
Instruction Manual can be found here:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Posted on Dec 14, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
Posted on Dec 22, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
Anonymous
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
Anonymous
SOURCE: I have a bosch classixx 6 1200 express washing
My Bosch washing machine is showing a key symbolt, is beeping and flashing shows O and will not let me start a new cycle.
Posted on Mar 21, 2010
F21 has appeared on my Bosch classixx 6 1200 model
F21 normally indicates a fault with the motor or the main control board. It could be the motor brushes need changing.
If you've changed the brushes you now need to erase the stored errors and try the machine again.
Turn the knob to off.
Close the door.
Turn the knob to 6 o'clock position.
Wait 2 seconds.
The start/pause should begin flashing.
Press and hold the spin button. (the spin button is the one that changes the spin speed, it may be marked "RPM")
Turn the knob to 7 o'clock position.
Wait 2 seconds.
Release the button.
This should erase the error code and get you running again.
If the error code returns, you have a problem with the motor, wiring or main control.
If the machine won't go into diagnostics to erase the error code, it would suggest a faulty control board.
Try it several times to see if you get it reset.
Note, If the start button doesn't flash, just carry on trying to erase the codes.
Dec 22, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1200 express lights flashing
Bosch 1200 classixx express washing machine. Upon switching on my machine, a little while later all of the lights on the control panel were flashing except the Start button. I tried to push the buttons but there was not the usual sound made upon depression of any of the buttons. They continued to flash. I switched the power off and cleaned out the pipes at the front of the machine to eliminate any obvious problems. Please help
Dec 05, 2011 | Bosch Washing Machines
My bosch classixx 1200 wont spin when on function but will spin by hand i have cleaned the pipes and checked the belt everything seems ok
It does sound as if the motor requires replacement because it is struggling, particularly when called upon to run the spin cycle. It is not uncommon to find that the brushes are worn sufficiently for them to not make perfect contact with the commutator at the higher speeds- bouncing and sparking. Now, a word or two of advice from this retired Englishman in SW France. It might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the commutator (like the worn ones!), often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor on our 19+ year-old Bosch at a cost of GBP250 ;-0(
The choice of course is entirely up to you- but do not forget that it is not an uncommon fault, especially if the washer is not exactly new. Others I have given this advice to have chosen new brushes and I don't blame them!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Apr 25, 2011 | Bosch Washing Machines
Hi there, have got a bosch 1200 classixx WF02466GB/01 - pumps working but will not spin the drum. Belt is ok and drum does move when you push it.
To make sure it is not due to water left in the drum, remove the filter, and clean.
If it still does not spin, then it is more than likely that the brushes need replacing in the motor..
You will have to remove the motor to check them..
If they are less than 3 or 4 mm long, then they need changing.
Hope this helps.
Dec 22, 2009 | Bosch Washing Machines
Flash from the back of the washing machine.
it sounds like the brushes have gone in the motor that turns the drum
Apr 21, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Thanks
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Changing the brushes when the motor is off
Remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Nov 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Not a programme error but carbon brushes on motor.Fixed by local engineer.
Aug 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Brushes
I just did this and had to take the motor off because I couldn't get to one of the brushes. It was easy to get off (only 2 bolts) and just as easy to put back on. Taking the motor off made life much easier as fitting the brushes is fiddly.
Jun 03, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Brushes
most brushs are screwed to the back of the motor which are very easy to replace,other are inside the motor and you have to dismanttle the motor.i hope this is what you wanted to know.your question wasnt clear.
Mar 06, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
137 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
