Garden Logo
Anonymous Posted on May 15, 2012
How do I adjust the carb on a FB25 weedeater blower??
Can't get it to start, i have done every thing eles. Need to know the turns on the 2 scews from bottom up?
Richard Haynes
Level 3:
Master:
  • Weedeater Master 673 Answers
  • Posted on Dec 13, 2017
Richard Haynes
Weedeater Master
Level 3:
Master:
Answers
673
Questions
0
Helped
208289
Points
1403
These need to be adjusted using a Tachnometer however to get the unit started. Turn the "L" screw in until it lightly seats then back out 1 1/2 turn. Do the same for the "H" screw. This should get the unit running then it can be fine tuned.
  • Stacy Flit
    Stacy Flit Jul 01, 2020
    The high screw is turned with the throttle at high speed. The L screw is idle. If it starts at 1 1/2 turns out let it warm up a bit no choke and then turn the L screw out a little more until it starts to bog then turn it back in until it bogs again then back out until the mid point idle speed is the highest and smoothest speed. Open up the throttle to a fast speed not wide open though adjust the H screw same as you did the L. Find the best spot where fast is strong running and that is it. No start is usual bad fuel line and or crud in the carb. Up and down engine speed is the governor and you have to adjust that. It is a process different on every engine so you will have to look at a shop manual or find a video with the same engine shown.
5 Related Answers
panilling9
panilling9
  • 284 Answers
  • Posted on May 26, 2009
SOURCE: need settings for carb gb1 22v
initial setting for for most carbs is 1 and 1/4 out for each
Mike Squire
  • 420 Answers
  • Posted on May 27, 2009
SOURCE: carb adjustments for weedeater model gb1 22v
If the blower has ran ok in the past but now not so good I doubt it is the adjustment to the carburetor, I would suspect bad fuel or old fuel first. Empty the blower of gas, pump the primer ball until all of the fuel is pushed through the carb and back to the tank. Add fresh fuel with a premium grade oil (I use gold spectra) and try it again, carburetors typically do not get out of adjustment. I own a 125 BT and have never had any trouble with it other than skunky fuel left over from the previous season.
Anonymous
  • 1990 Answers
  • Posted on Jan 23, 2009
SOURCE: Relacing fuel lines in a weedeater blower/vac
Sounds Correct on this End.
Anonymous
  • 124 Answers
  • Posted on Sep 20, 2009
SOURCE: Poulan leaf blower bv1850 Runs greate for about
Most likely low compression caused by stuck piston rings or a scored piston and cylinder. This unit was made by Poulan and they have had an epidemic of this problem. The solution is to tear the unit down and put in new piston rings. Before you install the new rings you need to get a sheet of glass and some 600 grit wet dry sand paper. Sand each ring down about .002 to .003 and reinstall. This should solve your problem as long as you have good fire and the piston and cylinder is not scored.
#1 Taper
Jim Parker
  • 1041 Answers
  • Posted on Nov 27, 2009
SOURCE: weedeater leaf blower FL1500
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray withcarb.cleaner.Make sure the small screen is free of debris. (Should beable to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
My hand held blower wont spark plug and carb.replaced still wont start
If the plug is wet with fuel and it is firing then pull the muffler and for a struck ring. Struck and bad score cylinders will cause one not to start as you need at least 100 psi of compression to ignite the fuel mix.
These are okay then check the ignition of the flywheel to coil relationship as it could be a sheared flywheel key. Note most 2 cycles are now using cast in key as part of the flywheel itself.
1helpful
Can a gas powered blower be repaired if it was drooped in pool.
it's hard to get it running again...probably it's not worth a try...
- you should open the carburetor, dry and clean it.
then the spark plug has to be removed and dried with a blow torch, also inside the cylinder opening.
then you better buy a can of starter spray to ease a start procedure.
Weed Eater FB25 Handheld Blower Parts 25311960-50ikml0pgld1svv5r0lj5py2-4-0.jpg 25311960-50ikml0pgld1svv5r0lj5py2-4-2.jpg
How do i adjust the carburetor high and low mix on a weedeaterblower fb25..
Initial start adjustment is 1 full turn out on both low and high side.
Weed eater fb25 25cc gas blower wont start
change the spark plug--put fresh fuel in gas tank 89 octane mix
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/david_2f6e03df6c124197
My fb25 starter rope won't recoil. how do I fix this please?
has to be taken apart for that, spring probably popped out of its groove
Weedeater fb25 runs too lean
Because of Federal Emission standards all newer 2 stroke engines are tuned extremely lean. You can have it adjusted and richen the mixture.
Weedeater FB25 5months old only used once and was hard to start right from the box. Can't get it to run now. What steps should I take on troubleshooting
This sounds much like poor car settings ( set too lean ) you need to richen up the L and H screw on the carb, unfortunatley there will be anti tamper sleeves on the carb or a special tool reqired to adjust them, turning the screws anti clockwise will richen the mixture if you manage to remove the caps or get hold of the apropriate tool.
1helpful
Ran well the 1st yr. Added Stabil - would not start this yr. Have put fresh gas in but will not start.
you added stabil but did you run the gas out of the carb? Take the carb apart and klean all with carb cleaner, spray in all holes. Check the plug gap of the new plug while your into the unit anyway the gap should only be 1mm.
Dennis
Top Weedeater Garden Experts
vince
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
