I used to have a canon mf4350d and if I pressed menu # it would enter service mode where I could view and reset "counts" and stored memory. I need to know how to on my canon MF4570dn. I send tons of faxes daily on mortgages and it eats memory. Any solution would be appreciated, canon suggested unplugging it that is there anwer to reset the stored memory.
SOURCE: fax in memory
Print from Fax Memory on MP530 1- Press Fax,then Menu. 2- Press the Right Arrow Key to show 'Memory Reference' on the mini screen.Then press OK. 3 - Again use the arrow keys to show 'Print Document' on mini screen and press OK to print. 4- Once this has printed repeat the first 2 steps and on the 3rd step go to 'Delete Document' to allow you to print the next saved fax. 5- Repeat this till you have no more Fax's saved,then the light should go out in the top left corner. Hope this helps.
SOURCE: Memory full display when trying ty fax
Thanks, I turned the power off and that didn't work. But pulling the plug did!!
Sharona
SOURCE: Call Customer Service 1-8O5-465-751O To Fix Issue canon mx700 fax report problems
after emailing canon support, the answer is this: 1) the fax paper size must be "letter" - 8.5-11". 2) reset all settings through settings menu. the fax will then print reports (and also every report that was not printed before).
SOURCE: can not clear memory in my canon MX850
First thing I would try is to reset the device by turning the device off, and waiting a full 20 seconds, then attempting to restart the printer, wait for it to do its full boot up cycle and then try again, if that doesn't work I might e-mail, or call Canon.
Hope this helps,
Ryan Frame
Creative Energy Associates Technical Center
SOURCE: my fax (pixma mx330)says memory in use and shows
Hi, you must reset the machine in the factory setting mode.
You may need to prevent your received faxes from being accessed by unauthorized people. You can turn on secure receiving mode to restrict printing of received faxes when the machine is unattended. In secure receiving mode, all incoming faxes go into memory. When the mode is deactivated, any stored faxes are printed.
Press (Fax) on the control panel.
Press Menu until Advanced Fax appear.
Press the left/right arrow until Secure Receive appear and press OK.
Press the left/right arrow until On appear and press OK.
Enter a four-digit password you want to use and press OK.
You can activate secure receiving mode without setting a password, but cannot protect your faxes.
Re-enter the password to confirm it and press OK.
Press Stop/Clear to return to ready mode.
When a fax is received in secure receiving mode, your machine stores it in memory and shows Secure Receive to let you know that there is a fax received.
Printing received faxes
Access the Secure Receive menu by following steps 1 through 3 in "Activating secure receiving mode."
Press the left/right arrow until Print appear and press OK.
Enter the four-digit password and press OK.
The machine prints all of the faxes stored in memory.
Press the left/right arrow until Off appear and press OK.
The mode is deactivated and the machine prints all faxes stored in memory.
Press Stop/Clear to return to ready mode."
