After a power cut and now with the power restored, the bottom oven won't come on. The led timer displays 3 flashing zeros and ''auto''. Trying to switch to manual does not seem to have any effect. Can you help?
I'm figuring you've probably resolved this, since you posted in November (and I've just joined the site today). However, I thought I'd post a solution just in case anyone else surfs in and finds the same problem.
We have the same sort of oven. After the power has been off, the oven won't work until you set the time on the clock. I think it's because of all the automatic timer features.
On ours, you have to press the two buttons with arrows on at the same time as turning the clock dial to change the time.
Good luck.
You must ensure that it is set to manualmor the oven will not work
We have the same problem. Have you been able to find a solution?
exactly the same problem after a power cut too, any ideas anyone...???
Theere is no display in the timer (described as "P" in the manual). That means, that I cannot use the auto mode or timer mode for cooking in the oven. ANy idea?
