Need new tires all around 12 volt john deer tractor and 1 and reverse gear dont work good
The tires tread is gone and it just spends and wont go up hills need tires were do we get them?
yes john deere turf tractor with arms that go up and down on the set
have some one activate it while you feel it if you feel a click or movement its working if not its bad then get a volt meter set to 12 volts ceck the voltage going to it 1 ground 1 hot if its grounded to frame it may have only 1 hot wire when its activated
GO ON LINE TO JOHN DEERE PARTS YOU CAN DOWN LOAD PARTS DIAGRAMS AND WIRING DIAGRAMS ALSO. CHECK THE PLUGS AN THE WIRING HARNESS AND MAKE SURE THEY ARE CLEAN. WITH A VOLT METER YOU CAN CHECK AND SEE WHAT VOLTAGE YOU ARE GETTING TO THAT RELAY. I DON'T HAVE A DIAGRAM TO LOOK AT BUT IF I CAN FIND ONE ONLINE I'LL LET YOU KNOW. HAVE YOU CHECKED FOR A SECOND RELAY
