Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Posted on Nov 22, 2008
Washer fills but won t advance to the next setting for all cycle
For all the cycles--the washer will fill continuously and won't move on to the next setting. The water stays on, but drains out--doesn't agitate or spin unless I manually move the dial. Help!
  • 1 more comment
  • nancyb2k3 Nov 22, 2008
    I don't hear that and someone else had actually suggested that might be the problem. Do you know what part I need to order? A new dial?
  • djulian27107 Dec 01, 2008
    My washer fills and begins the first wash cycle, but will not move on to the next cycle. What can you suggest.
  • Anonymous Mar 17, 2014
    Cycles work but won't draw in a drop of water
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Nov 22, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
Helped
40145
Points
39
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
3answers
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
1helpful
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
2helpful
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Washer just started on fill cycle to start and continued filling
you have a hose that came loose to the pressure switch or the tub or you have a bad pressure switch
or the fill cup is blocked
2helpful
Frigidaire washing machine gets stuck on cycles
Washer fills with water, spins but does not aggetate
LG washing machine, the water continue, not stop
New Whirlpool washer model WTW5700SW rinse cycle doesn't worker properly. The water never fills the tub & continues to drain. You have to manually move the dial to the end of the rinse cycle to have...
Sounds like what you are describing is the timer on the dial is not activating the next cycle. Timers are usually the problem when the cycles do not complete there cycle
2answers
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Washer only fills
it sounds as if its your lid switch. on some top load whirlpool washer it will fill even if the lid is open. if you open the control panel and open the jones plug you can check for continuity on the lid switch
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
