It makes a high pitch sound like metal on metal grinding tub does not spin well
Very common problem / ck the motor pulley / this is a double v pulley / top runs the main belt to the center and to bottom runs the pump . the lower side of pully has seperated and is running loose . replace it with the new style. it's is a one piece . and replace both belt as a set . this should solve problem/ good luck and thanks for ysing fix ya . ****
SOURCE: High pitch noise when Maytag
hi. thanks for the question. the problem you are having is with the water pump . some piece of metal or plastic is in the pump .check the water pump. thanks the appliance doc
SOURCE: maytag atlantis mav6000
sounds like the carbon brushes need replacing in the motor, they can cause a screeching sound as they wear down.
SOURCE: Noise when washer is in spin/rinse mode
most likely its the pump this is a simple repair just lean the machine back and remove the belt. if this machine has an access cover on rear remove it and disconcet the two hoses from the drain pump remove the three screws holding the pump in with a 3/8 scocket install new pump reconect hoses put back cover on put belt on and your done if no access panell on the rear just pop the top with a stiff putty knife at the front corners remove the front cover and the pump is right there on the right front corner remove it the same as rear put new pump on put cover on close top and your done
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
SOURCE: my maytag neptune tl washer is making a grinding noise
The pump has some debris in it. Clear the pump and you will be good to go.
