What does this mean and how do I fix this
The first step would be to verify power at the power supply and into the relay board. https://www.sportsmith.net/supportsearch...
Display reads CONFIG RQRD or NTM CONFIG RQD on Stairmaster Equipment
Probable Cause
The message CONFIG RQRD or NTM CONFIG RQD appears when the console needs to be configured for the machine type it is installed. This message is common when the console has been replaced or if the settings have been changed. Message is commonly seen on various Stairmaster equipment such as bike models 3000CE, 3300CE, 3400CE, 3600RC, 3800RC and 3900RC; stepper models 4400PT, 4600PT, 4400CL, 4600CL and SC916; stepmill models 7000PT and SM916; elliptical model ClubStride 5100.
Corrective Action
Stairmaster Console Message CONFIG RQRD or NTM CONFIG RQD
SOURCE: stairmaster climber model 4600 pt pedals go all
Unplug dc power connection then remove right side panel check for loose connections on on alternator, check distance of speed sensor to speed sensor disc you should no more than 3 credit card distance between them. Next remove the black wire from the B+ terminal on the alternator, then remove the brown wire from the field terminal on the alternator.Place a short wire with alligator clips between B+ and field terminals start stepping for about 10 to 15 second you should full resistance in that case its the upper console that if not replace alternator
SOURCE: looking for a manual for stairmaster 4600 free
Hi, I just purchased a used StairMaster 4600CL last week, and found a link for an owner's manual that covers the StairMaster FreeClimber 4200 PT, 4400 PT/CL, and 4600 PT/CL. This is a free, .pdf download:
http://gymstore.info/manuals/upload/StairMaster/stairmaster_freeclimber_4200_4400_4600pt_cl_c40_om.pdf
Vanessa
SOURCE: where can i find the power supply for stairmaster
contact sportsmith fitness products you can find them on the interenet
