GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator Logo
Posted on May 14, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I know if my compressor on my frig is bad?
Kevin Getz
Level 3:
Genius:
  • Master 1,032 Answers
  • Posted on May 15, 2012
Kevin Getz
Master
Level 3:
Genius:
Answers
1032
Questions
Helped
324454
Points
3063
If the thermostat clicks and nothing happens.
My magic chef model ctn1911gew is not working properly makes a clicking sound and is not cold at all and fan on bottom is not running. please help
Are we talking about the fan near the compressor? It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load itself is bad the compressor will not run. It will click trying to turn on untill the over load gets hot Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is not running could itself be the problem. It is needed to keep the freon, and the compressor cooled.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
I own a Fogel Fridge Model # VR-17-RE-PR Recently
Richard,
It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load otself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
At 100 deg.it does not shutoff automatically
If your talking about a refrigerator, it never will as its goal is to try and cool, and its trying. It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load itself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your frig is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
1helpful
Comptrssor cuts off wont start
Michael,
If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load itself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is getting really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off. I suspect the start/overload relay is bad and causes a high amperage draw which will then cause the over load to kick in. This start/over load relay will normally be right on the compressor and any decent appliance parts store will have a replacement.
Compressor is hot, but will not start. Just keep hearing a relay / contact clicking ebery few minutes.
Could be bad start/over load relay, or bad compressor. Try unplugging your frig for say 30 to 40 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. When the start/over load relay fails, it can apply power to both the compressors start coil AND it's run coil at the same time for to long and it very quickly causes and over load situation. I bet your "Starting Components" (start/over load relay) are bad. Any decent appliance parts store will have what you need. Just take in the make, model, and serial number of tour frig.
Frig keeps overloading circuit breaker, just repaced relay
I think the compressor has a problem with its internal running coil , or it's grounded.To check it you can disconect the power to the compressor and then turn on the breaker , and if doesn't tripped the breaker ,you know the compressor is bad.
3helpful
2answers
5 year old Amana bottom freezer. No cooling because compressor not working. Technician tried a starter but it short circuited. Now fridge is off. Worth buying new compressor or a new frig? Is this a...
you can have the compressor replaced for around 500usd on the norm. that would be the most inexpensive way to go compared to a new unit , it will come with a 90 day-1 year warranty.
Phil
Ice melted
Very possible your compressor is bad or the start capacitor is defective. Need someone to do an electrical test on compressor to eliminate the compressor.
Let me know if I can help further, Thanks Sea Breeze
2answers
Poping the curcuit braker
Your compressor is bad .Need to replaced, a way to test is unplugged the compressor and see if it stays on
Relay in kenmore frig
Yes it can. a short in the windings will cause a relay to fail. let me know if you want to make sure it is a compressor
Top Refrigerators Experts
vince
Johnny 1000
