Solution 1:
1. Go to file manager on your mobile
2. In Settings choose system folders,
3. In the System folder, find a file called mmcstore
4. Send the file to your PC using IR/Bluetooth
5. Open the file in Notepad
6. The password you need for your memory card is located within that file
Solution 2:
1. Download and Install FExplorer
2. Insert your card into your phone, without accessing it through the phone
3. Run FExplorer and Open the path C:system
4. Find the file called mmcstore, and rename it mmcstore.txt
5. Copy that file (mmcstore.txt) to your PC and open it in Notepad
6. Your password will be located within that file.
Solution 3:
1. Download and Instal X-Plore
2. Now open the X-Plore and press Zero(0) then check you have marked the
"Show the System Files".
3. After you done the above step now go to the file:
C:/Sys/Data/Mmcstore
4. If you found the above path then press the option "3" to set the Hex-Viewer.
5. Now look the third column you can see the code like ! TMSD02G (c ??"? x???3?3?3?3?3)
Now see the characters between '?' because it is your password 33333.
6. You mayn't able to access the path file:
if you don't set the password for the memory card.
SOURCE: i'm using nokia-2730 classsic mobile.
Try finding an unlocker because there is no way you can recover the password. or try 12345 (default password)
SOURCE: I have forgotten the memory card password in my
Insert the MicroSD card into an available media reader slot on your PC.
If your media reader can't read MicroSD cards, but can read ordinary
SD cards, first insert the MicroSD card into an SD adapter, and then
insert the adapter into the slot. You will see an autoplay menu for the
disk pop up on the screen.2 Open the folders on the disk and
navigate to the "System" folder. Click on the "Open folders to view
files" option from the autoplay menu, then double-click on the folder
that says "System." This is where your card's password file is stored.3 Open the password file. In the
"System" folder, find the file that has MMCSTORE somewhere in its name.
It may have additional letters, numbers and characters, but it will
always have MMCSTORE in the title. Double-click on this file to open it
in Notepad. The text inside this file is your lost Micro SD password.
SOURCE: i forgt my memory card password of nokia 3500c
http://www.mobiclue.com/2009/02/recover-memory-card-password-from.html
try out this..myt help you..!!
SOURCE: I have Nokia E71 and i forgot the password of my memory card
hi,since there's no software to recover this,its not possible for you to get the password,the only thing you can do is to reformat the memory card,but this will make you lose your datas or files in the memory card.thanks,you are welcomed.
Testimonial: "thanks a lot, at least you explain for me the possibilities even if loosing the data which i really want :( but thanks a lot"
FExplorer software
As I said, we need to download Fexplorer software for this mobile hack. After installation, Browse to c:\system folder in your mobile phone. Here you would find a file mmcstore. This file is actually used to store memory card passwords in a mobile phone. Rename this file to mmcstore.txt and open with notepad. Now you will see the memory card password as
it is, exactly. Mobile manufactures are now aware of this trick, and
nowadays they use better encryption methods to block access to
passwords.
Method 2: Unlock or reset memory card password of Nokia phones:
The first hack to recover the password of memory cards will not work on Nokia Nseries and Nokia Eseries
devices. Here we will use the remote lock feature for re-setting the
password. For this, go to your phones settings >Security >Phone
and SIM> and then allow Remote lock. The password of your remote lock
will be the password of your memory card. So if you want to change the memory card password, just send an SMS containing your remote lock message.
