My emerson tv model BLC320EM9 is at its worst. i have tried unplugging the power cord from the outlet and pressing buttons on remote but only power button works and everytime my tv turns on from power it flashes 13 times. exactly thirteen times. unless this is an indication of a tv code. can someone please tell me what this code for this tv means?
SOURCE: NEW EMERSON 20" LCD STERO TV/DVD- NOT WORKING
the flash was the fuse inside the set blowing it usually takes out one or two diodes in the power supply section but maybeyou got lucky and its only the fuse.
SOURCE: CODE FOR A REMOTE CONTROL
I am not sure of the model remote but, on the newer TW remotes you would press tv then press and hold set up until the tv light blinks twice. then enter 991 on the number pad and then press power once. then press the channel up button until the tv turns off. as soon as it turns off - press the power button and if it turns on then you have the right code. If it doesn't turn on then press channel down until it turns on. either way, when the tv turns on then press set up again to lock that code in. Hope that helps.
SOURCE: I have an Emerson LCD
Tries tv unplug,replug it back like about an hour later.The tv now it resetting itself back to factory setting should work again.If have the same problems,the tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
SOURCE: Emerson LC320EM1 flat TV will not turn on. Green
try turning off the power saverv feature
software problem ?
