Question about KitchenAid K45SS Classic Stand Mixer
Kitchen aid mixer won't run
Just won't turn on. No humming or any noise. acts as if the switch is bad. There were no problems or indications anything was wrong until it broke. I rotated the brushes but that did not help.
    Dedicated:
    Visited the website for 20 consecutive days.
  • KitchenAid Expert
  • 169 Answers
Hiya,
I am sorry to hear you are having trouble with your mixer.
Please check if your motor brushes have been put in correctly as this may be the issue. I have added links below for our help video on motor brushes which may help you:
https://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidMixerHelp/KitchenAidMotorBrushReplacement/tabid/597/Default.aspx
https://www.youtube.com/watch?v=5YuS3atXR0M
I hope this helps you solve the problem! :)
Posted on Oct 04, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: kitchen aid proline mixer MODEL:
check the worm gear, teeth most likely broken
Posted on Jan 15, 2009
advacak
Denny Adams
  • 125 Answers
SOURCE: kitchen aid mixer
take off the chrome ring around the rotator. remove the screws that were hiding under it. pull off the rotator and replace the "O" ring on the shaft.
Posted on Mar 09, 2009
mastatech
mark milligan
  • 478 Answers
SOURCE: my kitchen aid mixer makes a clicking sound when it is on
Check the motor brushes. You'll see two black plugs with flathead screwdrivera small one, Unscrew to check, if only springs or very worn,youll,know.Its a maintenance problem.
Posted on Mar 11, 2009
Anonymous
  • 16 Answers
SOURCE: kitchenaid mixer speed
I would recommend that you first check the Hall Effect sensor which determines the mixer’s speed.  I had this exact problem and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My mixer worked as good as new! But I was curious to know if my original sensor was defective, so I put it back in mixer and again made sure all of the connections were snug and tight. Guess what?  My original sensor also made my mixer work!  There was nothing wrong with the original Hall Effect sensor except that the connection between the control board and sensor was not tight--unfortunately I didn't check the connection before I decided to buy another sensor. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations. To fix your problem:
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall Effect sensor looks like. BTW the part number is 9703312.
2.  You'll need a phillips head screwdriver to open up the mixer gear case cover.
3.  Make sure that the connection between the control board and sensor is absolutely tight and snug.
4.  Also, make sure that the orientation of the sensor is correct.  It's difficult to tell which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or down. After you've made the connection, run the mixer. If it still doesn't work, disconnect the sensor, reconnect it with the prongs facing the opposite direction and try it again.  I actually found the right sensor orientation through a little trial and error.  But by going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work if it were reconnected with correct orientation.
5.  This whole process probably takes about 10-15 minutes to perform.
6.  Finally, use your common sense and make sure to unplug the mixer before checking, connecting or disconnecting anything.
Posted on Mar 21, 2009
seakish
  • 492 Answers
SOURCE: Kitchen Aid 10 speed 325watts
Some of the gears may have broken or slipped off. You'll need t open it up to see why the shaft from the motor will not spin or you will burn out the motor with the power on trying to make it go. It might be a DIY job if you can see an obvious problem like a slipped gear, otherwise take it to a repair specialist.
Posted on Apr 30, 2009
I have a kitchen aid stand mixer. model #rkt2651x. it goes very fast when turned on then shuts off. it will go again but turns right off again. age?
That is indicative of worn motors brushes or a speed regulation circuit board problem. It is worth getting it fixed.
I just checked and my diagnosis is sound :>)
I have a kitchen aid stand mixer. model #rkt2651x. it goes - Fixya
www.fixya.com/support/t26909658-kitchen_aid_stand_mixer_model
52 mins ago - i have a kitchen aid stand mixer. model #rkt2651x. it goes very fast when turned on then shuts off. it will go - Food Mixers question. SOLVED: Mixer goes really fast then stops
29 Dec 2007
Questions, Troubleshooting Help & Support Page 3
28 Jul 2006
More results from www.fixya.com
KitchenAid Classic Mixer K45SSWH Troubleshooting - iFixit
https://www.ifixit.com/Wiki/KitchenAid_Classic_Mixer_K45SSWH_Troubleshooting Make sure the KitchenAid Mixer is firmly plugged into a working outlet and the cord is not twisted or split. ... If your mixer still will not turn on, it might be a problem with the motor brushes. If the brushes are worn down ... The most common sign of a failing hall sensor is if your mixer increases to top speed and then shuts down. Missing: rkt2651x
Stand Mixer Shuts Off During Use - KitchenAid Product Help
producthelp.kitchenaid.com > ... > Stand Mixer Assembly and Operation Jul 12, 2017 - Once the steam has dissipated, the unit should turn on again (about 3 minutes). Resolution: If the mixer could have overheated during use let the mixer cool for at least 30 minutes and try to re-start. If you were making mashed potatoes when the mixer shut off it's possible that with excessive steam the unit ... Missing: rkt2651x
images for kitchen aid rkt2651x stand mixer goes very ...
More images for kitchen aid rkt2651x stand mixer goes very fast when turned on then shuts offReport images
FAQs - KitchenAid
https://kitchenaid.com.au/faqs Explore our range of frequently asked questions to get the very most out of your KitchenAid product. Missing: rkt2651x
[PDF]Classic Stand Mixer Speed Control - KitchenAid
https://kitchenaid.com.au/sites/.../stand_mixer_service_manual_speed_control_6-12.p... KitchenAid®. Classic Stand Mixer. Speed Control. Theory of Operation. And. Troubleshooting Guide. (revision date 6/19/2012). D. Pahl ... Mixer Does Not Shut Off page 6. Mixer Does Not Turn On page 7 ... the motor is not running (OFF) the governor ball plate is at its farthest forward position and when the motor is running at ... Missing: rkt2651x
How to Replace the Speed Sensor and Control Board on a KitchenAid ...
? 6:28
https://www.youtube.com/watch?v=41qTqTWQkMI Jan 15, 2013 - Uploaded by eReplacementParts.com
This video tutorial will show you how to replace the speed sensor and control board on a KitchenAid Pro 6 ...Missing: rkt2651x ‎turned kitchenaid rkt2651x stand mixer goes very fast when turned on then shuts...
Mar 10, 2018 | Food Mixers
My Kitchen aid Ksm90 mixer got a little noisy, then it just wouldn't even turn on. What could be wrong with it?
You have possibly blown the fuse gear. Need a bit more info on the noise. If you turn it on slow and help the planetary does it try go get itself going?
Jan 16, 2015 | KitchenAid Kitchen Aid Ultra Power Tilt...
Kitchen aid artisan model # KSM150PSBU
You have put the "chalk thing" back in incorrectly, it only fits one way, use a torch and look in the hole and line the missing corner on the "chalk thing" up with the blocker.
Jul 26, 2013 | Food Mixers
Kitchenaid mixer 600 won't turn on
bread is very tuff on mixers. always buy the strongest mixer that you can afford. im guessing the field in the motor fried.
Feb 07, 2013 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
Jan 14, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Who repairs kitchen aid mixers
Call the Kitchen Aid small appliance warranty office and they will tell you where the authorized repair person is that is close to you.
Dec 16, 2012 | KitchenAid K45SS Classic Stand Mixer
The speed lever on my KSM 90 won't lock in the off position.
Do you have a manual? You can download one from Kitchen Aid, small appliances. There should be a schematic and how to that will help.
Dec 16, 2012 | KitchenAid KSM90 Ultra Power Series Stand...
My kitchen aid K5SS won't run
first check the motor brush and replace them with a new pair. if you never do that check youtube and see a video how to do it.
Dec 05, 2012 | KitchenAid K5SS Heavy Duty Commercial...
Bad switch on kitchen aid mixer
Unfortunately you will probably need to split the gearcase to sort out the speed control arm.
Nov 30, 2012 | KitchenAid Kitchen Aid Mixer Stainless...
Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
Jul 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid K45SS Classic Stand Mixer Logo
354 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
