Edimax BR-6114Wg Router (BR6114WG) Logo
Anonymous Posted on Dec 18, 2006
Wireless connection keeps falling
Hello, I've been having this problem for quite a while. When I first open the router everything seems to work fine but after a few minutes I can't surf. The connection signal is strong and I can use the desktop but not on my laptop. BTW, the signal is strong and the wireless connection is strong. When I get close to the router with my laptio everything seems to be working well again. Any idea?
  • Anonymous Jan 20, 2007
    Thanks for your help.
    It seems that the problem was that the signal was too low (the router was placed in a shelter room).
    Anyway i placed the router on a higher shelf and now it seems to be working.
  • Anonymous Mar 28, 2014
    all was fine a few days ago, now apps dont play, strong WiFi signal, all sync'd ok, now cannot configure settings to get working again
Anonymous
Level 3:
President:
  • Master 2,961 Answers
  • Posted on Dec 19, 2006
Anonymous
Master
Level 3:
President:
Answers
2961
Questions
Helped
1637798
Points
8444
It may be just a problem of the signal bouncing around and your laptop is struggling at times to find the signal. Some earlier laptops don't have a wireless booster built in the screen. Go to your laptops' web site and see if there are any updated drivers for your wireless card. If still unhappy with results purchase a USB wireless dongle and dissable wireless card, it may have a better reception area, or purchase a signal booster that works in conjunction with your wireless router.
1helpful
How do I connect to wireless and Ethernet?
If you installed windows recently you may be missing the drivers if that is the case go to the manufacturer website and download the drivers. Best of luck to you hope I helped
My Netgear Router keeps kicking all wireless devices off the network
Upgrade your firmware for router (apps).
I hope, it helps.
Feel free to get instant Netgear router help at http://www.vtechsquad.com/wireless-router-support/ to fix any issues with your Netgear or any other router.
Adapter inactive
It is not the problem with the router. It is the problem with the wireless adapter on your computer. Open Network connections and look for Wireless network connection. If it is not there then open the Device Manager and look for Wireless network adapter under Network adapters. It seems that wireless adapter on your computer is not working or it is not detected by your computer. If you have external wireless adapter then unplug it and replug it.
1helpful
Can't open setup page from Encore ENHWI-N3
The best way to open the setup page is to have a wired connection to the router. Once you plugin the router to both the modem and the computer, you want to reboot everything. After you've established a connection, open a browser window and go to 192.168.0.1. To login to the setup page, enter admin for user and admin for password. From there you can change your password and setup the secured wireless networking.
You should also be able to try this wirelessly, but you must be sure that you have selected the Encore network on your computer's wireless control panel.
Hello, I followed the installation instructions with Wizard and was told I successfully installed the router. However, when I try to connect (wireless network connection) it tells me that Windows is unable...
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
2answers
Router stops working if mozilla firefox 4 is turned on but not used for 30-60 mins
A browser can not affect your router. Some thing else would be th cause I would suggest upgrading the firmware to your wireless router.
Router Wont COnnect To Internet
Reboot your modem, router, and computer. Power them all down (unplug the modem and router if necessary) then boot the Modem, then after a minute boot the router, then your PC and see if all is well, it should be.
Using Wireless + PPPoE at the same time kills router. SMCWBR14-G2
From your description, I am assuming you have a direct ethernet connection from an RJ45 connection in a jack in the wall. If this is the case, then you would just need to purchase a wireless router (linksys, D-link, netgear, etc). Connect the ethernet connection from the wall to the routers internet or WAN port. You will need to access the routers firmware configuration and set it to connect with PPPoE, so get your username and password from your ISP if you are not sure what it is.
You will be able to continue to have the PC plugged into the router with an ethernet cable, and then run the laptop with a wireless connection, just be sure to configure the laptop with the security key if applicable.
If you were using a software PPPoE connection on your PC, quit using it. Just set your network adapters on both computers to DHCP, and you should be good to go.
Hope this helps
Chris (ziraffa)
Cannot connect anymore
Does the router work with the wired port connection? It's entirely possible that the router just went belly-up on you ...Linksys is an awesome brand, but sometimes it happens.
If the wired part works, the wireless transmitter inside may have gone bad. Best to just get a new one for about $50 ...but keep the old one in case you need a wired connection somewhere else around the house :)
Wireless connectivity
hi,
connect to rourter wired
open ur router page
and run the set up
Top Edimax Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
