Treadmill has been randomly not starting - no response when touchpad button was pressed. Jiggling the display ribbon cable would usually get it going. Can't get it start at all now. Lights on board are lit.
1)LUBE the deck belt, maybe you have a deck belt worn, by lack maintenance.
2) Lube the rollers bearings, in according with the maintenance schedule.
3) Test the main motor for voltage input, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
5) After fixing RUN the software calibration for diagnose, and troubleshooting.
SOURCE: Landice L7 gives me a L5 reading on the screen
Your L7 error looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
SOURCE: the treadmill comes on but but the belt doesnt
At first glance, It looks like a lower control board issue and/or motor issue (more likely lower control board).
Before calling Landice I would check all the connections to the Lower control board. I would also check under the display overlay if all the connections are good.
I know it is not much, but I hope it helps.
