Question about Reebok treadmill i-run s
Adjust voltage on motor control board - Reebok treadmill i-run s
    Top Expert:
  • Reebok Master
  • 12,223 Answers
Dear Sir:
You can adjut the voltage motor in m.m.board.
The only way is 1) Put some regulator voltage in the line for to maintain the voltage in the line Good 2)Try to get some circuit special for your treadmill without interference 3) You can add the voltage from the transformer inside from your machine.
However You can RUN the software calibration for diagnose, troubleshooting, and fix it.
sincerely. God bless you
Posted on May 08, 2012
Anonymous
SOURCE:
Controller what is the voltages output on a healthrider s300i
the voltage controller is the same for input voltage terminal of the motor .
test the input voltage terminal motor, if there ARE not the motor is faulty.Read my personal TIPS motor
2) test the output voltage control board, if there ARE not the control board is faulty
God bless you
Oct 21, 2013 | HEALTHRIDER S300i Treadmill Motor Control...
I have Merit 710T that has recently begun to smell. I have lubricated the belt and had some problems readjusting the tightness and alignment but now that its aligned the treadmill gives me about 30 minutes...
see the video attached, lube TOO the rollers bearing front +back.
see the video how to adjust the deck belt.God bless you
However if finally the problem persist, test the input voltage motor see my personal TIPS, if there are Voltage at the terminals, the motor is faulty. Measure the output Voltage from the control board
for to input to the Motor, if there are NOT voltage from output the control BOARD is faulty, replace.
Oct 07, 2013 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
C2050 belt does not turn
LUBE THE deck belt inmediattely, maybe you have WORN deck belt
2) LUBE the rollers bearing too
3) test the drive belt motor for worn, replace or adjust it
4) test the input voltage motor, if there are the motor need repair, See my personal TIPS.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 24, 2012 | Nordic Track Nordictrack C2050 Treadmill...
Error code E0
1) adjust the speed sensor see the diagram attached. tight the cable, and clean it.
2)test the input voltage motor, if there are the motor need repair.
3)test the output voltage from the motor controller, for input voltage motor if there are NOT the motor controller need replace.
God bless you
Nov 08, 2012 | Sportcraft Tx2.5 Tx 2.5 Treadmill Motor...
My mot566 tread mill carl lewis keep say EO1
1) adjust the speed sensor, see the diagram attached, clean, and tigh the wires connector.
2) measure the input voltage motor, if there are the motor need repair
3) measurre the output voltage board, for input voltage motor, if there are NOT the board is faulty.
See the block diagram how the main board control the 90% of the treadmill.
God bless you
Jun 24, 2012 | Exercise & Fitness
My horizon 4.1t treadmill will incline/decline but does not run. showing an e1 error. please help
1) Adjust the speed sensor, clean, and tight the connector very well
see the diagram
2) Lube the deck belt, by lack of maintenance,
3) Test the motor input voltage, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor,if there are the board is ffaulty.
RUN the software calibration for diagnose and troubleshooting.
May 09, 2012 | Exercise & Fitness
Treamill wont move with wiehg ton belt
Drive belt may not have adequate tension, motor brushes may be worn out, tread tension may be too tight, one or more of the control devices may have failed, the power to the treadmill is inadequate.
Drive belt can be viewed with the motor cover removed. If it slips, adjust tension until static belt delfection is about 1/8 inch.
If motor halts with load and belt does not slip, adjust the tread tension by turning the track tension bolts counter clockwise 1/4 turn at a time, both adjusters evenly. If no improvement 1 full turn in, check motor and or control board.
if tread adjustment does not help, check the brushes to make sure they are not hanging up in the holder. Remove the plastic caps that retain the brush inthe motor with treadmill unplugged, If they are 1/4 inch in length or shorter- replace brushes. If the motor does not have brushes, it is an AC type motor.
If brushes are fine, check motor voltage with an analog voltmeter- AC range if you have the open frame AC type of motor where you can see the windings (no brushes) and measure voltage on theboard terminals that go to motor. They should adjust from zero to at least 80 volts via the speed control knob. If the AC motor hums a great deal, replace the motor run capacitor.
If you have the DC motor, (usually about the size of a 1 liter bottle.), Check voltage range, it should have the same voltage range as above with meter set to DC range.
If in either case the motor moves fine, but full speed on control does not yield full motor speed, check the devices, usually SCR or Triacs on the AC motor type and MOSFETS or IGBT on the DC motor types.
Jan 23, 2012 | Exercise & Fitness
T931 not starting
1) Exchange batteries by new ones.
2)Tight the flexible cord Keypanel vs display board.
3) Tight the connector from display board vs lower board.
4) Adjust the sensor reed switch see the diagram by 1/8"
5)put your software calibration to work, for diagnostic and adjust.see the instruction in your owner manual y/o under hood.
6) Adjust the speed sensor and tigh the connector very well.
7)Test the main motor for 115VAC, see the plate from motor for to check the voltage.
8)See the main motor board or lower board, Test for 115 Vac, and +5VDC for output from the main controller board and display board
See the block diagram and take the diagnostic very effective. sincerely.
Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a.
Dec 22, 2011 | Exercise & Fitness
On my proform 680LTwhen I put the key in I get an FF display and nothing works
You must to the following:
Adjust the Sensor Reed, or optical sensor. by 1/8" or 3mms if see the diagram.
If after adjustment the problem persist. You must Test or measure the voltage for +5vdc to I.C.( EPROM, ROM, etc) , coming up from the Lower Board( Main Controller Motor Board).
Re-connect the flexible cord between Upper Board(Display) VS. Lower Board(Main Controller Motor Board) .
After you did that the Display Board is faulty or Main Controller Motor Board is faulty Replace.
Of course try to use the Dvoltmeter. very important.
sincerely.
Nov 22, 2011 | Proform 680 LT Treadmill
The six way power seat on my 2005 suburban has an issue. When I turn the motor off and remove the key the motor goes to it's down and back position but continues to run. And it doesn't respond to the...
The first place to start would be to have the dealer or someother qualified repair shop , that has a professional scan tool read DTC'S - diagnostic trouble codes in the driver seat module ! The seat adjuster motors are controlled by the driver seat module through the adjuster motor control circuits. In an inactive state both of the motor control circuits are grounded within the driver seat module. In an active state the driver seat module switches the appropriate motor control circuit to battery positive voltage. The direction of the adjuster motor rotation is determined by which of the motor control circuits is switched to battery positive voltage while the other remains grounded. During adjuster motor operation the driver seat module also monitors the current flow through the motor control circuits.
DTC B1770, B1775, B1780, B1785, B1790, B1805, or B2415
B1825 , B1850, B1860, B1960, B2355, B2365, or B2375
B3962
Memory Seat System Components
The memory seat system consists of the following components:
• Power seat switch assembly
• Memory recall switch assembly
• Horizontal adjuster motor
• Front vertical adjuster motor
• Rear vertical adjuster motor
• Recline adjuster motor
• Driver seat module
• Driver door module
• SEAT 30A circuit breaker
Memory Seat System Description
Battery voltage is supplied to the driver seat module through the power seat circuit breaker. The driver seat module supplies the seat adjuster switch assembly with a battery positive reference voltage. While the seat adjuster switches are in an inactive state the switch contacts are closed to the adjuster switch ground circuit. When a seat adjuster switch is pressed to an active state the switch contact is closed to the reference voltage circuit. Battery voltage on a switch signal circuit indicates to the driver seat module the switch status is active. Each seat adjuster motor is controlled by the driver seat module through 2 motor control circuits. While the seat adjuster motors are in an inactive state the motor control circuits are closed to ground circuit contacts within the driver seat module. The driver seat module operates the seat adjuster motors by switching one of a motor's control circuits to battery voltage. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
Memory Set/Recall Operation
The seat adjuster motors are equipped with internal position sensors. The adjuster motor position sensors are monitored by the driver seat module and are used to determine the seat position when storing or recalling memory settings. The horizontal, front vertical, and rear vertical adjuster motors use hall effect type position sensors. The hall effect position sensors are supplied with battery positive reference and ground circuits from the driver seat module. The position sensor signal circuits are supplied battery positive voltage through a resistor them monitored within the driver seat module. During adjuster motor operation the hall effect position sensor provides a single pulse for every revolution of the adjuster motor shaft. The driver seat module counts the pulses from the position sensor signal circuits to determine the adjuster motor positions when storing or recalling memory seat position settings. The recline adjuster motor is equipped with a potentiometer type position sensor. The recline motor position sensor is supplied with it's own 5-volt reference ground circuits from the driver seat module. The recline position sensor signal circuit is referenced from ground within the driver seat module. The signal voltage monitored by the driver seat module ranges from 0.39 - 4.58 volts and is determined by the wiper location on the resistor within the recline motor position sensor. The recline motor position sensor signal circuit voltage level is used by the driver seat module to determine the seat recline position when storing or recalling memory seat position settings.
The memory recall switch assembly on the driver's door provides inputs to the driver door module. Battery voltage is supplied to the memory
Feb 06, 2018 | Chevrolet Suburban Cars & Trucks
Reebok treadmill i-run s Logo
131 people viewed this question
Top Reebok Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Christopher DeSantis
Level 1 Expert
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
