Emerson Smartset Clock Radio Logo
Posted on Nov 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have had this clock radio for about 2 years now. At times it will show only part of the numbers and the radio will not work. I have unplugged it and then plugged it back in and still doesn't work. But if I unplug it for a day or two and then plug it back in I have to set the time and the radio will begin working again. What is the problem?
  • moenster Nov 19, 2008
    What is the problem with my clock radio?
Anonymous
Level 3:
President:
  • Master 814 Answers
  • Posted on Jun 14, 2009
Anonymous
Master
Level 3:
President:
Answers
814
Questions
0
Helped
447782
Points
1474
Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!
5 Related Answers
Anonymous
  • Posted on Aug 02, 2008
SOURCE: My Emerson Smartset Clock Radio CKS3516
I returned the clock!
A
Anonymous
  • Posted on Oct 11, 2008
SOURCE: Emerson SmartSet Dual Alarm Clock Radio Won't Stop "Flickering"
Problem was solved. When clock was plugged in after a few more days, it finally stopped flickering and reported an incorrect time and day. Low battery was now blinking! Checked calendar and found all memory was lost. Purchased and installed a new battery and this time when clock was plugged in it correctly set itself! Fixed.
Anonymous
  • 814 Answers
  • Posted on Jun 11, 2009
SOURCE: SmartSEt Clock Radio went to military time
You can reset the time from military to regular time by holding down the time button and let it cycle to the normal time. I hope this information help you with your problem.
Anonymous
  • 814 Answers
  • Posted on Jun 12, 2009
SOURCE: Emerson Smartset Clock Radio
For the Clock/Radios that are having problems with the clock display and settings. You will have to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio from the wall outlet and remove the internal battery. You must let the Clock/Radio set with no power for at least 1 hour to discharge the microprocessor circuits. The microprocessor should then be able to reset itself. You can then reinsert the battery and plug the Clock/Radio into the a/c wall outlet. The functions should have reset and be working normally. If this does not solve the problem, try putting in a new battery (CR2430). Before putting in the new battery, unplug the clock radio and remove the old battery and let it set again for a few hours this time to try to reset the microprocessor. If this does not solve the problem (This includes the person with the complete Clock/Radio operation failure) you can call the Emerson customer support at this telephone number 1-800-898-9020. Give them the make and model number of the Clock/Radio. Tell them the problems you are having with the operation of the Clock/Radio and ask them for assistance. I hope this information helps you solve the problems your are having with your Clock/ Radios.
Anonymous
  • 814 Answers
  • Posted on Jun 13, 2009
SOURCE: emerson clock radio cks 3516 military time
You will need to try some combination of the set button and time button to change the time back to normal time. Try hold both the time and set button for a period of 5-10 seconds and see if this will cycle the time to normal. If not try hold the set button alone for 5-10 seconds and see if this works. If not try holding the time time button for 5-10 seconds and see if that works. If none of the fixes work. Call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 9am-5pm CT. Tell them the make and model number of your Clock/Radio and ask them for assistance with your problem of resetting the time back to normal from military time. They will be able to help you. I hope this information helps you solve your problem.
3helpful
How do you set the alarm for pacific standard time on the emerson
Here is the procedure for setting the time zones for your Clock/Radio. Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time I will give you the web link for the owners manual so you can find any other information you might need for your Clock/Radio. (http://www.emersonradio.com/owners/iPod%20Series/iC200_042007.pdf) copy this web address and paste it in the address bard of your browser and it will take you to a pdf copy of the owners manual. I hope this information help you with your problem.
tip
Daylight Saving Time Changes for SmartSet Clock/Radios
Dear Emerson SmartSet® Clock/Clock Radio Owner:
Your Emerson SmartSet® Clock or Clock Radio includes Emerson’s patentedAuto Time Setting System that
automatically sets the clock to the correct year, month, date, day and time, the first time that you plug it in, and
after every power interruption. It also includes a built-in long life lithium battery that can maintain the time and
alarm settings for up to 5 years, or even longer.
As an added benefit we have programmed the internal SmartSet® computer to automatically adjust for Standard/
Daylight Saving Time changes through the year 2097. TheDaylight Saving Time information programmed into
all SmartSet® models was based on the United States Uniform TimeAct of 1966, which formalized theDaylight
Saving Time period that we observe today. CurrentlyDaylight Saving Time begins on the first Sunday in April
and ends on the last Sunday in October.
The new Energy Bill that was signed into law by President Bush in August 2005 includes a provision to
extend Daylight Saving Time. Beginning in 2007 Daylight Saving Time will begin on the second Sunday in
March and end on the first Sunday in November.
Of course this is a situation that is beyond the control of Emerson, or any other company that produces
devices with an automaticDaylight Saving Time adjustment feature. For example most computers, PDA’s, and
many other devices also have automatic DST adjustments. Manufacturers of these devices must now begin to
make adjustments to the automatic DST software to agree with the new DST timing for 2007.
Beginning in 2007 the current automatic DST default settings in this device would no longer be correct. It
would then be necessary for you to manually adjust the TIME ZONE setting 4 times each year as follows:
1.) On the second Sunday in March you would have to set your clock to the next lower number time zone.
For example if you lived in the Eastern Time zone (Zone 02) you would then change your clock to Zone
1 to move it ahead by one hour.
2.) On the first Sunday in April, this clock will automatically advance by one hour. You must then set the
clock back to your correct time zone. For example if you lived in the Eastern Time zone you would set
your clock back to Zone 02.
3.) On the last Sunday in October you would again set your clock to the next lower numbered time zone.
4.) On the first Sunday in November you would again set your clock back to your correct time zone.
Instructions for changing the Time Zone setting are found in the Owner’s Manual.
We apologize for any inconvenience this may cause due to circumstances that are beyond our control.
Printed in China
508-02
tip
Procedure For Setting Time Zones For Emerson Clock Radios
zone. If you live in the Eastern Time zone, there’s nothing else to do. Your
interruption.
ZONE 1 — Atlantic Time
ZONE 2 — Eastern Time (Default Setting)
ZONE 3 — Central Time
ZONE 4 — Mountain Time
ZONE 5 — Pacific Time
ZONE 6 — Yukon Time
ZONE 7 — Hawaiian Time
The number “02” will appear on the display
Eastern Time
3helpful
2answers
How to reset Emerson SmartSet AC100 Alarm/Radio for DST changes!!
No way to change it to automatically do it without replacing the data chip. I changed the time zone from 3 to 2 in the fall and then have to switch back to zone 3 in April.
My Emerson clock radio was manufactured in 2001. Model #CKS2000N; S/N10339233BA. Need to set clock for DST. I do not have a "month" year button - only a "time" year button. Can you help? Thank you
For this model Clock radio you will have to call Emerson Customer support at this telephone number.1-800-909-1240 between the hours of 8am-4:30pm CT. Tell them the make and model number of your Clock/Radio and ask them for assistance. You will probably be told that,your Clock/Radio has no updating feature. This is because at that time there was no need for such a feature. The best way to get the new features is to buy a new Clock/Radio. Thank you for using FixYA and have a nice day.
1helpful
After 2 years Smartset presents problems
You must try to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C power source.Then remove the Internal battery(CR2430). Let the Clock/Radio set without a power source for about 3 hours. This will discharge the microprocessor and reset it. After you have discharged the microprocessor,you can reinstall the internal battery. Connect the Clock/Radio to the A/C power source. The Clock/Radio's Functions should have returned to normal function. If the Clock/Radio did not return to normal function, you must replace the internal battery and again let the microprocessor discharge. After the microprocessor has discharged,put in the new internal battery and reconnect the Clock/Radio to the A/C power source. The Clock/Radio should have returned to normal function. If you are still having problem with the functions of the Clock/Radio, You will have to call Emerson Customer Support. The telephone number for the Emerson customer support is 1-800-909-1240. you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problems with the Clock/Radio. Thank you for using FixYa and have a nice day!
The clock does not show the correct time.
[http://www.emersonradio.com/owners/SmartSet%20Series/] copy this web link and paste it into the address bar of your web browser. It will take you to the Emerson customer web page for the pdf copies of the SmartSet Clock/Radios. You will need a pdf reader and writer to read and make a copy of the owners manual for yourself.Find the make and model number of your Clock/Radio. The instructions for resetting the time after changing the battery will be in the manual. I hope this information helps you with your problem. Than you for using FixYa and have a nice day.
2answers
Emerson Research SmartSet Clock Radio
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
Sorry it took so long to give you a answer to your question. For this information about the switching of the month/day function, you will need to contact Emerson Customer Support. The Emerson Customer Support telephone number is 1-800-909-1240 you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance. I hope this information help you with your question. Thank you for using FixYa and have a nice day.
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
