Did the linkage change on the newer 42" mower deck? My older deck have a specific bracket welded on to allow the linkage to connect with the tractor to engaged the cutting blades. This new deck appears to have missing or there was a change in design leaving the bracket off. The manual show the bracket, but not connected to anything, Yet, the manual shows a spring connecting to the anti-sway bar bracket with a spring attached with a housing guide leading to take-up pulley that engages the mower blades.
SOURCE: deck repair
It goes on top of the littlie flat idler on the right side,
the right and left side is by sitting on unit.
You will see a little hole in the top of the bolt a little pin goes in there and holds it in place.
SOURCE: loud screech noise from deck area
This can be due to a belt slipping or a bad spindle bearing.
And on the difficulty scale,10 being extremely difficult, The belt would be a 1 or 2 and the spindle about 6 or 7 (because the deck usually needs removed for this job)
SOURCE: need a manual for a LT1000 craftsman 19 1/2 HP 42 inch mower deck
You can download a free copy at www.managemyhome.com or you can go to www.searspartsdirect.com and buy a copy along with look at the diagram that you need.
