SOURCE: waste ink counter reset canon pixma mp190 photo
HI you can try
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings.
From what I gather, it’s both a time consuming and expensive proposition to take to Canon to fix.
And they won't tell people how to do it themselves.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free.
You have to be slightly mechanical to do this.
If you you've never used a screwdriver and are all thumbs, but give it a shot or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
1.You will include printer
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
into the service regime
3. Select NVRAM ACCESS and further BY OK.
4. Select SET Abs- m level and advance value equal to zero
5. Select SET Abs- r level (if there is) and also you will establish into zero
6. You will turn off printer by button POWER.
SOURCE: Reset Waste Ink Canon MX318
Because It is full. And replace or you can clean it. Either way you must any of this two things.
Good luck.
SOURCE: Canon pixma mp240 ink reset
Thats funny, cause I took the cartridges out and left the lid up, unplugged it, plugged it back in with my finger on the power button and tapped the stop/reset button twice. Put the cartridges in, pressed the color start, after some moaning a test page printed. I unplugged it again, plugged it back in and I had full ink Levels!!!
SOURCE: canon mp 390 waste ink near full
Some user tried the procedure to reset waste ink tanf full on Canon MP 360 and ... Reset Ink Level for Canon MX300 · Reset Counter Canon iP1500 and iP1000 ...
tricks-collections.com/waste-ink-tank-full-reset-canon-mp360/
SOURCE: waste ink counter reset for canon pixma mp190 all
Hi there
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Release power button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
