Acer aspire 5315 modem device on high definition audio bus driver needed
All driver could be download from link below:-
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com/au&siteid=8116&areaid=12&formid=3394#results
Goto the following url
ftp://ftp.work.acer-euro.com/notebook/aspire_5315/vista/
Download the following file:
Modem_Agere_v7.66.0.50_Vista.zip
unzip the file to your desktop. Right Click "My Computer", Click "Properties", click the "Hardware" tab, then "Device Manager". under Modems, right click the error (should have a yellow exclamation mark) and click "Update Driver". Click "No, not this time", then "Install from a list or specific location (Advanced). Click "Browse" and find the folder called "Modem_Agere_v7.66.0.50_Vista". Then click "Ok". Windows should then search and install the driver automatically.
Plz check the manufacture website for the drivers
Hi i purchase lenovo 4EQ Y500 SERIES MODEL
I WANT TO DO RECOVERY KEY IN MY SYSTEM
SO CAN U TELL ME HOW CAN WE DO START AND USE RECOVERY KEY BUTTON
DIS TIME ITS NOT WORKING
Try downloading the following driver: Even though it says Vista, it works well with XP too.
I had the same problem I went to the Acer download site (http://support.acer.com/drivers_download.aspx) and downloaded the driver ( Agere Modem Driver 2.1.77.9 680.4 KB 2008/12/03) and selected the setup option , after unzipping the file it resolved the issue confirmed in Device Manager , thanx for the tip
I have an acer 3680 that worked fine and 5315 that did not. It also had the same modem in "AGERE" moden in it.. so when i went to install hardware in desktop, I selected my own modem driverfrom the list in XP and in there is only one selection for AGERE and that driver worked perfect. I went to acer and got the driver fo my 3680 and it did not work. so I had the driver all the time in XP go to add hardware.. I now have a ACER 5315 that works great. I also got the ALPS origanol driver from dell and installed it for xp and it is just like the origanol. Good luck Greg
Problem modem device on high definition audio bus driver download acer 5315
and adobe flash setup
SOURCE: Modem device on high definition Audio Bus for acer aspire 3680
If you have downloaded and unzipped the audio drivers try this.
- Know the location of those driver files.
Open start, run, type in compmgmt.msc, from there select Device Manager
Look under Sound / video controller, find exclamation device HD audio, right-click, update driver, search for your audio driver location and install.
SOURCE: Sound problem on Acer Aspire 5315
you want to download a new sound driver i think your sound driver is not working
SOURCE: i need the mass storage
If you were to log on to the acer.com web site, I think you will be pleasantly surprised as
usually one is able to download if available, by model number,
Customer Instruction Manuals,
list of Dealers,
for
spare parts and service, Driver
downloads
and
Installation Instructions as required. This is the best way of ensuring up to
date drivers for your system and they are free of charge! There
are no XP drivers to be found with Microsoft as XP is no longer
supported. Some
manufacturers may have a limited number of Drivers still listed. I hope this helps.
SOURCE: I need to find drivers for Acer Aspire
Hi
Thank you for your query
Please can you try the following
1) download install and run devicedoctor from
http://www.devicedoctor.com/
2) Click scan and it should pick up for the missing drivers above
3) Download and install the missing drivers
Regards
Shauqat
SOURCE: Modem driver problem for Acer Aspire 4315 Notebook
you download driver for modem...
http://support.acer-euro.com/drivers/notebook/as_4315.html
have same problemo.....driver for xp 5315 modem..#%^$%$^^&%&^.....
hi:
my name is patricia, i have a acer 5315 (notebook)and i dont serch driver of "Modem device on high definition audio bus (acer 5315)" for windows XP.
I need help please
att patricia mejia
Mexico
i need driver for modem device on high audio definition for xp for acer aspire 5315
esse link nao esta dando certo
mesmo assim obrigado
I found a site with all Acer Aspire 5315 drivers. But using linux i lost the site and needed it no more. But i try to find it out again and send it to you
i have the same problem
acer a spire 5315 modem device on high definition audio bus
acer aspire 5315 modem device on high definition audio bus driver
