SOURCE: I have an electric Traeger grill. I plug it in
Make sure your grill is unplugged. Them take the controler out and there is a fuse on the back side of the control. There is also a new fuse there to replace the old one. If the fuse is blown, you could have a bad hot rod or other component that is bad. Usually the hot rod is the problem and they should be under warrenty so call Treager and get a new one sent. If the fuse blows after it is replace, you can un hook the purple wire and replace the fuse and see if it will work them. If it does, it is the hotrod.
