Red key lock is a common fault.....firstly switch of ...un plug machine from wall. Leave for 30 minutes...open drain plug at bottom right hand with a butter knife...remove plastic filter an wash thoroughly. Ensure water drains into a flat container or towel.Refit. Remove 4 screws from back panel feel rubber pipe attached to pump. There may be something jamming maybe a sock. If nothing is jamiming, replace back cover. By now door will open. Do a quick wash without any clothes. Red lock will flash ....do not worry. After cycle machine will stop and END will light up.....problem solved.....hope this helps...prem 0844066421.....I am not a machine repairman but an estate agent in kempton park.
It can be the door lock servo which is a ****** to reach or tamper with as it's a sealed unit, I sorted mine by draining via the filter port at the bottom right front behind the rectangular front panel ( this will normally fill a small saucepan half way when machine is level which is the best way to drain although you will be using a cellulose sponge to soak the water from the floor rather than directly into the pan) then tilting from the front 45 degrees or more backwards. This all being done with power off and water inlet pipe disconnected as this can and will snap readily. Having rested back down to a level try the door again and smile.
SOURCE: Door won't open on Samsung washer
This has happened to me twice. Both times I found the drain pump seized up with
1st time) The right rim from a pair of reading glasses
2nd time) A plastic toothpick
Both times the object was in the discharge port of the pump. You can see this by lifting the check valve with the pump removed. Removing the pump is simple. Unplug the washer. You have to remove the drain line from where its attached to the rear of the machine (one screw) to remove the rear access panel which slides into upper and lower slots. You will see the pump with an inlet and discharge line attached. The lines have simple squeeze clamps. When you remove the lines, you will drain the wash basin so have towels and a squeegie handy. Remove both lines and wait until the basin drains. When it stops draining remove the pumps electrical connector by squeezing the release catch on it while pulling it. The connector can only go on one way. Remove the 3 hold-down bolts on the pump baseplate. Remove the pump and lift open the discharge check valve and you'll find something there I guarantee it. Remove with needle nose pliers and re-assemble in reverse order.
This is actually a good design because the computer protects the pump by sensing a higher than normal current draw when foreign debris gets jammed in it. It will trigger the ND (No Drain) code and sometimes lock the door. Always check this first before you call the expensive repair man. If its not a jammed pump it will most likely be the control panel/processor. Good luck and always clean out pockets before loading the washer to prevent this,
SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
SOURCE: Philips Whirlpool 400 AWG 370 door is locked
take the kick panel off and reach up the right side where the door lock is. there is a release pull down that releases the door.
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
SOURCE: door stuck shut hot point wd420
It happened on our machine. The soloution to this for me was to take the lid off (two screws). Unplugged from mains. I found the connector to the door had vibrated off and was just hanging loose. Plugged it back in and it worked straight away.Door opens as normal.
Don't forget to look in the manual for how to get the door open in an emergency
