1. [URL=http://imageshack.us/photo/my-images/502/95785220.png/][IMG]http://img502.imageshack.us/img502/3048/95785220.png[/IMG][/URL] 2. [URL=http://imageshack.us/photo/my-images/525/45258862.png/][IMG]http://img525.imageshack.us/img525/5040/45258862.png[/IMG][/URL] when I authorize then going on 1 step again :| please help.
Autorize you computer in itunes. https://images.pcworld.com/images/article/2011/10/screenshot1-5231863.png
SOURCE: help me pls. i cannot put my playlist from my itunes to my iphone
click on iphone in itunes then go to music, check Sync Music and press apply an you should be good to go
SOURCE: iPhone 3G Error 0xE8000001
I just had this problem and it turned out to be... It didn't like my iPod cable. Switched to the iPhone cable and it worked.
Seems to be an iPhone 2.0 prob, or 3g prob, since I was using the iPod cable to sync my old iPhone just fine.
SOURCE: iphone 2g wont sync
Please look here:
iphone Troubleshooting Assistant
http://www.apple.com/support/iphone/troubleshooting/phone/
Reset and Restore iPhone to Original Default Factory Settings with Recovery Mode
iPhone display freezing?
iPhone doesn’t detect by or appear in iTunes? iPhone cannot sync with
iTunes on PC or Mac? Cannot make or receive calls, send or receive text
messages, or access email or the web? Or worse, iPhone simply won’t
turn on and does not respond to tap or button press? If the problem
still persists after you have reseted the iPhone, or tried various iPhone troubleshooting,
it may be worthwhile to invoke recovery mode to restore iPhone to
default factory settings, the original state as when you first received
and unwrapped the phone.
Restoration of iPhone to original factory defaults will likely to fix
all problem, with the downside that all data and information stored on
your phone will be lost. Normally iTunes will make a backup
automatically when you connect and sync the iPhone with the program,
however, it’s still a good recommendation to copy out and backup
everything that you may need on the phone before proceed to restore the
iPhone.
To restore iPhone and reset the phone to default factory settings, follow these steps:
http://www.mydigitallife.info/2007/10/04/reset-and-restore-iphone-to-original-default-factory-settings-with-recovery-mode/
SOURCE: Text Error 1121611611
In order to send a text message on the iPhone, you must have the entire 10-digit phone number in your phonebook. For example. If you are trying to send a text message to the phone number 555-1234, you must also enter the area code. If the area code it 412, you must put in 4125551234 for the phone number.
Hope this helps!!
SOURCE: how to sync .ipa files from comp to iphone thru itunes ?
when you sync the iPhone with the computer, iTunes will only add what is new, it will not delete your apps.
Setting Up Syncing
You use iTunes on your computer to set up which items are synced. Make sure you have the most recent version of iTunes (On a PC, open iTunes and choose Help > Check for Updates. On a Mac, open iTunes and choose iTunes > Check for Updates.
Step 1: Connect iPhone or iPod touch
Step 2: Set Up Which Items Are Synced
Click the respective tabs in iTunes to specify which media and information you want synced from your computer to iPhone or iPod touch.
For more information about syncing iPhone with your computer see the iPhone User's Guide:
On your computer: click here to download and view "Chapter 1: Getting Started" in iPhone User Guide.
On iPhone: Tap Safari and view http://help.apple.com/iphone/guide/.
For more information about syncing iPod touch with your computer:
On your computer, click here to download and view "Chapter 1: Getting Started" in iPod touch User Guide.
On iPod touch: Tap Safari and view http://help.apple.com/ipodtouch/guide/.
Step 3: Sync iPhone or iPod touch
Click Apply in the lower-right corner of the screen. Your computer syncs with iPhone or iPod touch according to your settings.
The first time you sync iPhone or iPod touch, you are asked if you want to merge data, replace data on the service, or replace the data on your computer. After that, anytime you connect iPhone or iPod touch to your computer, iTunes opens and syncs with iPhone or iPod touch according to your settings.
You can adjust sync settings anytime iPhone or iPod touch is connected to your computer. You can only connect and sync with one iPhone or iPod touch at the same time. If you need to sync more than one iPhone or iPod touch, disconnect one before connecting the other.
Note: Syncing won't delete any contact in Yahoo! Address Book that contains a Messenger ID, even if you've deleted the contact from your address book on iPhone or your computer. To delete a contact containing a Messenger ID, log in to your Yahoo! account online and delete the contact using Yahoo! Address Book.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
If you've set up automatic syncing, iTunes syncs your device by default whenever you connect your iPod, iPhone, or iPad to your computer. If you don't want iTunes to sync your device without being prompted, you can change this setting.
You can prevent unprompted syncing for any specific iPod, iPhone, or iPad; or for all iPod, iPhone, or iPad devices you connect to your computer.
Connect your iPod, iPhone, or iPad to your computer.
In iTunes, select your device (below Devices).
Click Summary, and then deselect "Open iTunes when this Device is connected."
In iTunes, choose Edit > Preferences.
Click Devices.
Select "Prevent iPods, iPhones, and iPads from syncing automatically."
If this checkbox is selected, any connected iPod, iPhone, or iPad won't sync without being prompted.
To sync your iPod, iPhone, or iPad when unprompted syncing is disabled, connect your iPod, iPhone, or iPad to your computer, and then choose File > Sync "Device Name" in iTunes, or click your device (below Devices) and then click Sync.
For more information, see the iPod, iPhone, or iPad User Guide or the Apple Support website.
computer asks to be authenticated before every sync. clicking authorize button tells me this computer is already authorized then going on 1 step to authorize again.
