I had filled it with water, put coffee in and put jug on heater, pressed switch and red light comes on. Nothing further happens - normally water starts to go through the system after a few moments but nothing happens now. Any help please - its only about 9/10 months old and was working great. Thank you, Flor butler [email protected]
SOURCE: Espresso side works, Coffee side doesn't
I run in through after pouring a whole bottle of vinegar where the water goes. It needs to be done every 6 months or so due to build up.
SOURCE: water container full but low indication on
I think the water level is read by a magnetic pick up driven by a black floater located 3/4 way towards the back of the water tank.
Make sure this floater can move up and down in its pocket: you can see it through the walls so just shake the tank to see it move, and check that it floats up when you fill water
SOURCE: no water is pumping thru the water spout or the
I got this machine and there was grinding noise but no water coming from the spout or coffee from the dispenser.
Took the back cover off. The big lump in the middle is the water pump. One of the wire connections was hanging off mine. Pushed the connector back on and everything worked fine.
Great coffee, rubbish construction!
SOURCE: i cleaned my delonghi magnifica and now nothing
have u switch it on on back cover ??? ummm make sure u have the bucket sat in correctly .....and tray is in properly... have you snapped off the peg on the rear of the bucket for wast ?? its located rear of bucket. bsc appliances bristol 07779933829 postal service too.
SOURCE: My coffee maker, a DeLonghi
Most likely, it has an open thermal fuse or failed circuit control board. If it is under warranty replace
it, else you need to take to near by service centre to get it repaired.
Hope this helps.
Shane
