This Error with migration of data occurs when the connectivity is not proper with the Tally ERP ODBC. It includes the IP:Port.
The Default port for Tally ERP is 9090.
To change the port go to the installed tally ERP 9 folder. Click on Tally file type Configuration Settings, open it with a text Editor i.e. Notepad. Somewhere at the bottom will be ServerPort. Change the ServerPort to 9090. The migration will work. I have tested. Works fine with me.
Beautifully in a spur of the momment,it started working
thanks yaar its work like charm
Sir u are great. I am trying for several times after i found it works. Thanks a lot from my heart.
Friends we are here to help each other. If you'll have any other querry please post it.
dude i have a cracked version but its nt working ... need help
i have to folder one is tally and another one is tally.erp9, the erp9 named folder does not contain any such tally file
*two
my os is win8
Marvellous.... Struggled for 3 hrs before I stumbled upon your posting..... Your are just a Saviour
thanks buddy
are you talking about tallycfg file? cant find server port, pl help
I change the port to 9100 and it worked thanks a lot
Thank you soooo much....
Thanks a lot man. You saved my JOB!!!
Thanks buddy
Thanks buddy
THANKS ,EXCELLENT SOLUTION FROM -SUJAY SHAH
IT WORKED VERY WELL
tally 7.2 ka (1)01-04-05 to31.03.20 tak data migrat nahi hota , (2) kam data 01,04,19 to 31,03,20 ka data migrat ho raha he dono companies alag alag he (1) no.wali compny ka data migrat ka kya solution he
THANKS. IT WORKS..... VERY VERY THANKFUL.
Thank u fusion91fear
it worked for me
EXITING TALLY
ERROR 00005
MEMORY ACCESS VIOLATION
MESSGAE DISPLAYED WHEN TRY TO MIGRATE TALLY7.2 DATA TO TALLY9
Thank U So Much
Aatik Tamboli.
Thank u so much dear
SOURCE: MIGRATE EASY SOFTWARE-PARTION SIZE DID NOT INCREASE
when u clone a drive it copies the same size to if you are using vista it is easy to expand go into admin tools then computer management then click on your drive and expand it
SOURCE: Using Windows Vista I load Alohabob PC Relocator Ultra Contol
Sounds like you may need to Right-Click the shortcut or executable and click the command Run as administrator. If your account is an admin account, this extra step normally rectifies the issue.
SOURCE: PCMover program missing configuration screens
Some programs are in ex : express, standart, silver, gold version. The low payed programs as express often do only allow to ex : copy all the things to the new computer, for getting more features you need to purchase to a higher versions.
Hope thats help :O)
