My MW511 was working then stopped suddenly and all the lights came on and would not turn off by the 'Power' button so I unplugged the mains power supply.Now when the mains power is connected nothing happens - i.e. when pressing the 'power' button no lights turn on. Can you help solve my problem. Many thanks, Keith.
SOURCE: Whirlpool Calypso - Will not start
We just experienced the same problem with the buttons! I just kept pushing all the buttons until it switched over-delicate cycle was actually the one that got it going-what a piece of work this machine is!
SOURCE: Start up Fault
there should be a trouble shooter in the console the blinking lights will tell you what the problem is and the common issues are listed on that paper.
SOURCE: Infocus 60md10 not turning on
Mine was doing this for a while and now is completely black all the
time. I have a thought as to what this might be... I believe the
problem is not the lamp or light engine but rather one of the brushless
fans failing. This causes the tv to shut down as a safety measure
because of the inability to purge the heat that would build up VERY
QUICKLY and warp, damage and destroy everything else. I believe the
problem being intermittent at first is due to the fan performing a
"death rattle". The fan itself could be fine and more of an indirect
problem. I believe the wiring coming out of the fan is inadequately
insulated against the heat generated. It begins to cook, crack and
eventually fail.
The good news? If it is the fan they cost about $15 and can be
purchased on the internet. Nothing special about them. You would want
to make sure it has the same leads coming out of the fan to facilitate
the changeout. Again, I haven't attempted to install a new fan on mine
yet but it will be the first thing I try.
If any of you attempt this before I do, please post your resulting
experience for the rest of us. I will do the same. Good luck.
SOURCE: I have an Emprex Model WT323 LCD tv.
Does the lights on the front have a pattern to them or does it just turn on green and stay that way? If the lights have a pattern or turns on green then goes to orange or some other color then I would start with the power board. If the light stays green the whole time then I would turn all the lights off and shine a flashlight up real close to the screen and see if you see anything. If you do then it is your inverter board which controls your backlights.
Good Luck
