Garden Logo
Anonymous Posted on Apr 26, 2012
Lawnmower question: I have an Ariens EZR 1648 lawnmower. When I try to turn it over, it doesn't start. It only clicks. I did check the battery and it has a full charge. I checked the connectio
  • Anonymous Apr 27, 2012
    thanks, I'll try that.
Anonymous
Level 3:
Brigadier General:
  • Master 6,468 Answers
  • Posted on Apr 27, 2012
Anonymous
Master
Level 3:
Brigadier General:
Answers
6468
Questions
0
Helped
2131748
Points
13357
Try and jump it direct to the starter that way you can see if the problem is the starter or the wiring/safety switches
5 Related Answers
Anonymous
  • 37 Answers
  • Posted on Nov 23, 2008
SOURCE: mountfield sp470
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
Anonymous
  • 57 Answers
  • Posted on May 15, 2009
SOURCE: I have a lawnmower with a BSA 3.5 engine
Test for spark by placing a screwdriver into the spark plug wire and holding it close to a bolt on the engine. should see a spark (blue). If not, problem is likely the armature (coil). The coil is located under the engine shroud and held in place by two bolts. If you replace this part, (normally $30 to $40) you must ensure a proper air gap. Auto parts stores have inexpensive repair manuals to help.
Lee
Cherokee Small Engines
Anonymous
  • 998 Answers
  • Posted on Aug 08, 2009
SOURCE: My 550 series Bolens lawnmower won't start. When
keep pushing the prime button
colinjhought
  • 126 Answers
  • Posted on Aug 24, 2009
SOURCE: My Lawnmower starts but then shuts off after 1-2 minutes.
dirty carb likely. you may want to clean out the float bowl and that may be all that is required or it may need a more extensive cleaning. your gas tank may have dirt in it as well.
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Aug 15, 2010
SOURCE: 3.5 HP Lawnmower engine and it rus for only 30 seconds
Sounds like you will need to clean your carburetor even tho you said you alread did.
Make sure to blow out all the jets with compressed air, beware of small parts sometimes in the jets such as seats for the fuel float jet seat.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me,
Thanks
Good Luck,
I hope this helped
Schematics for Ariens EZR 1648
google images works the best.
Ariens EZR 1648 dies when pto is engaged
sounds like a bad safety switch
How do I Determine why my lawnmower went dead?
It appears to be an electrical issue. Check the switch under the seat, mower engagement and others. Go to the Ariens website for more information on your specific riding mower.
http://ariens.custhelp.com/app/answers/detail/a_id/15/
My ariens 1648 ezr won't go straight
Sounds like you have some type of wear on your steering linkage. Carefully inspect the steering gear for abnormal wear or damage.
Remove gas from Ariens 42" zero turn lawnmower
easiest way is to remove the tank and dump it out. you can also remove the fuel line at the carburetor and allow it to drain out there into an approved container. if you choose the latter be sure to have the cap off the tank to allow air in
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
2helpful
MY RIDING LAWNMOWER STARTER JUST CLICKS.I BOUGHT A NEW STARTER AND IT DOES THE SAME THING.
didnt specify type of rider but can b 1 of a few different problems-the clicking is the relay to the starter-- 1st check that motor turns if motor bound or seized starter wont turn it over -check that starter gear and flywheel mesh correctly if not might have to shim or adjust ,next check battery {full charge}and connections ,wiring ,and the fuses for corrosion and or damage.check the safety switches next the seat ,brake,and blade on, these switches will not let motor start if damaged ,activated,or bad wire.
Model A173K22 Primer Where?
What? !O_O!
Oh,.....................I was going to say, I don't remember any laptops coming with a priming feature, lol!
In answer to your question there is no priming feature, for an Ariens walk behind gas lawnmower, model A173K22,
Page 9,
http://www.managemylife.com/mmh/owner_manuals/134166/ARIENS-Walk-Behind-Lawnmower-Gas-1011731L
Regards,
joecoolvette
Top Garden Experts
Jay Finke
Jay Finke
john h
