On 2002 Oldsmobile Alero Car Light Bulb Size, check this list:
Low Beam Headlight Bulb Size: 9006 or 9006 HID Upgrade KitHigh Beam Headlight Bulb Size: 9005 or 9005 HID Upgrade KitParking Light Bulb Size: 3157NALLFront Turn Signal Light Bulb Size: 3157NALLRear Turn Signal Light Bulb Size: 3157LLTail Light Bulb Size: 3157LLStop Light Bulb Size: 3157LLHigh Mount Stop Light Bulb Size: 921Fog/Driving Light Bulb Size: 894License Plate Light Bulb Size: 194Back Up Light Bulb Size: 921Front Side Marker Light Bulb Size: 194Rear Side Marker Light Bulb Size: 2825Glove Box Light Bulb Size: 194Map Light Bulb Size: 212-2Dome Light Bulb Size: 212-2 or 561Step/Courtesy Light Bulb Size: 168 or 73Trunk/Cargo Area Light Bulb Size: 211-2
Hope helps.
SOURCE: how to change antifreeze in a 2002 oldsmobile alero
below radioator or side low should b plastic plug which u can unscrew & emty the fluid
SOURCE: Why can't 2002 Oldsmobile Alero won't shift into park or reverse
1st check the shifting cable on drivers side of engine.
SOURCE: how to change water pump in 2002 alero and a
I suggest that you visit the autozone.com website and register the vehicle. It doesn't cost anything and will give you access to an online repair manual. The steps for replacing the water pump should be available there. Hope this helped and best wishes.
SOURCE: the turn signals on my 2002 alero work only sometimes
fuse is most likely blown for lighter, cjk your owners manual for where an dwhich fuse. the turn signal switch is likely bad. if it wont signal, jiggle the lever, if it works then, have it repalced.
SOURCE: i need to reset the chage oil light for an alero
Instructions
Things You'll Need:
One button should have a road or "i" on it. Pushing this button will show your mileage, tire pressure, operating temperature, and all sorts of other stuff.
You are looking for "oil life ##%". Once you find this, press and hold the button with the checkmark on it. After 5-10 seconds it should flash "oil life reset". Tada!
Turn the car "On" (without starting car!!)
Press the gas pedal all the way to the floor 3 times within 5 seconds. This is trickier than it sounds. It must be pressed ALL the way to the floor ALL 3 times.
Then wait 5-10 seconds. The Change Oil Soon light should blink then go out. If not, turn the car off and go through the steps again.
