Section 00-02: Lifting, Jacking and Spare Tire Stowage
1995 Aerostar, Ranger, Explorer Workshop Manual
TIRE STOWAGE
Tire, Spare, Removal, Aerostar
If the Aerostar is a standard length vehicle the spare tire is mounted inside to a carrier at the left rear quarter panel. To remove the spare tire, remove the wing nut and plate. A flat tire can be temporarily stowed in the same location.
If the Aerostar is the bus with a standard length body or extended length (all models), the temporary spare tire is stowed at the rear of the vehicle under the body.
The Aerostar standard length E-4WD bus spare tire is mounted on the floor.
- Insert lug nut wrench into the actuator hole and turn counterclockwise until the cable extends to allow the spare tire to be pulled rearward from under the vehicle.
- Slide spare tire to the rear and remove the retainer from the wheel.
- To stow cable/retainer with spare tire removed, insert cable fitting into carrier rear wall slot, place wheel retainer against the carrier, and turn lug nut wrench clockwise until slack is removed.
please rate, thanks
