Refrigerator side of samsung side by side is not cooling correctly. Evap keeps icing up. I have replace the thermistor and checked all fans and all is working correctly. Why is it still icing up?
Is it freezing from the bottom up? If so check the drain is clear. If it's freezing all over, check the condenser is clean and clear and the compressor switches off when it reaches temperature. Lastly, check the door seals properly all the way round
Can you put it into a manual defrost? If you can, see if the evaporator gets warm enough to get rid of the frost build up. I'm assuming it's an electric defrost, not hot gas?
Does it fully defrost when it defrosts, including getting rid of all it's condensate down the drain? Can you extend the defrost time or end temperature to allow for a more efficient defrost? Is the defrost probe correctly sited on the evaporator?
Aah! If it's a hot gas defrost and the compressor is running but not defrosting it is the solenoid at fault. Almost certainly the coil burnt out, but may be the valve itself. Feel the pipework after the coil in defrost. It should be really hot, and the valve should clunk if you lift and drop the coil.
Are there 2 compressors? In effect two systems side by side?
SOURCE: samsung rs21dcns fridge freezer Ice
Found an electrical drawing and resolved the issue - Broken cable
SOURCE: what commponents keep a samsung model rs2630sh?
witch fan?
when was the last time you took the back off to clean the condenser?
needs to be cleaned every 6 months.
SOURCE: Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Testimonial: "Thanks for your help. The control board was faulty. This is what I suspected but I wanted a second opinion before buying the board. "
SOURCE: rs21 samsung twin cooling
These usually have one compressor and an evaporator on each side with a fan. check the fans first then the defrost timer, heater and limit thermostat.
Drain is Clear. And have done all the rest. I believe its a defrost problem. Worked perfectly after i replaced the Thermistor but only for about a month. Now the refrigerator is at 55 degrees.
Its the Hot Gas Defrost. Thats why im a little stumped.
Its not defrosting at all. Thats the problem. Yeah the sensors are in the correct location. Thanks for all the help.
I thought that was it as well but the freezer defrosts perfectly. Is there 2 valves? Thanks again for all the help
Nah. I was just wondering if there was two reversing valves. Does the freezer and refrigerator defrost with the same system at the same time? The freezer is defrosting okay. Im thinking its the control board possibly
